Msd digital 6 question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 05-03-2009, 11:13 PM Thread Starter
Trader Feedback: (43)
I have a digital 6 6531 ignition box with a 67mm turbo.
When i hit the 2-step and floor it, the car holds at about 3000rpm and builds bout 3-4 psi tops and when i let off it the BOV snaps, so i know im making boost.
SHOULD i be making more boost????
thanks
my wg spring is set at 9, and i see 9-10 when i stab it.
Precision 67mm turbo, this and that.
Thewhite88pony is offline
post #2 of 14 Old 05-06-2009, 01:41 AM
92stanggt5.0's Avatar
If I am correct on this which I may not be. You may have to set the 2 step higher to build more boost. I'm sure someone will jump in here and correct me but thats fine.
1995 Cobra white/tan and a T64
92stanggt5.0 is offline
post #3 of 14 Old 05-06-2009, 04:01 AM
357poweredstang's Avatar
I dont think so....there's not much load in neutral and at that low rpm...the more load an engine has on it the better the boost will build...someone correct me if im wrong
87 GT 306 machined/built by me..Windsor Jr heads, E cam, GT40, lt's, Tremec 3550 etc....Tweecer R/T tuned PLX wideband
Bunch of parts for sale..306, fully forged 347, 0 mile 357, Fully Forged 408, tremec trans, clutch, and more....
357poweredstang is offline
post #4 of 14 Old 05-06-2009, 06:54 AM
jixxer's Avatar
When there is no load on the car as in a 5sp car you also won't to pull some timing away when you are on the two step for a little more boost, the digital 6 has that option which makes it nice.
1990 Titanium Frost Coupe, Quicktime Turbo Systems, Silverfox 700 AOD, Dirtydog Converter, TFS Heads, 42lb Injectors, E 303 cam, 501 RWHP
jixxer is offline
post #5 of 14 Old 05-06-2009, 11:21 AM
red89coupe's Avatar
Trader Feedback: (31)
set the 2 step higher and pull timing.
when you put my car on the 2 set it was set at 3800 and pulling some timing.
gonna be harder for your motor to make boost sitting still then mine... WAY more motor lol
red89coupe is offline
post #6 of 14 Old 05-06-2009, 01:49 PM
Angry_Man's Avatar
Late burning fuel will spin it up some more. Plus you got to love the bat mobile flames out the exhaust.
Angry_Man is offline
post #7 of 14 Old 05-19-2009, 04:33 PM
Thunder5.0's Avatar
On the 2 step, I see 10 lbs. of boost. I have the Digital 6 with a 62mm.
Thunder5.0 is offline
post #8 of 14 Old 05-19-2009, 06:27 PM
jturmanator's Avatar
Same problem here with no luck.
jturmanator is offline
post #9 of 14 Old 05-19-2009, 07:36 PM
red89coupe's Avatar
Nate... did the tune change your 2 step boost??
same here..
post #10 of 14 Old 05-19-2009, 07:54 PM Thread Starter
wouldnt know, i have wiring problems now so the car is sitting.
post #11 of 14 Old 05-20-2009, 09:27 PM
red89coupe's Avatar
I hear it needs a clutch too?? damn man that sucks.
post #12 of 14 Old 05-20-2009, 10:16 PM Thread Starter
wiring is fine was a loose wire, i think the turbo already smoked my centerforce.
yay for 550 lbs of torque lol
hit me on aim or call the cell hb
post #13 of 14 Old 05-20-2009, 10:31 PM
How have you smoked the centerforce on street tires? I'm still running the stock clutch with M/T drag radials. I have made about a dozen passes.
post #14 of 14 Old 06-04-2009, 01:42 PM
Here is a video of my Digital 6 at 3k rpm.
http://www.youtube.com/watch?v=vNSxTVA6mk4
I have done some tweaking and bumped the rpms and it gets about 5lb-8lbs... It sure punishes the 265's in the rear at a stoplight dhaha.
1993 Silver Coupe
8.25:1, F-303 cam, TFS Track Heats, BBK SSI Intake, 42lb inj, Tremec 3550, 3,73's, Pypes Exhaust, 03 Cobra brakes.
Hellion "Heat" kit - 66mm T-Trim w/GTK housing. 8lbs for now. (435hp/460tq)
HellionFox is offline
msd digital 6 plus question freakgt General Mustang Tech 1 03-07-2007 04:05 PM
MSD Digital 6 Question? Stang730 5.0/5.8 Engine Tech 0 09-18-2006 07:06 PM
MSD 8969 Digital RPM switch question Pontisteve Drag Racing 0 03-03-2006 02:54 AM
MSD Digital 6 wiring question KJ94GT 94/95 Tech 0 10-14-2003 03:35 AM
Simple MSD DIgital 6 Question '89-LX-5.0 5.0/5.8 Engine Tech 1 03-25-2002 08:34 PM
