tried to fire up the car today...oil leak! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 05-03-2009, 09:35 PM Thread Starter
I tried to fire up my car for the first time since my quicktime install and the oil feed line is leaking bad! Its leaking right out the end of the crimp where it connects to the stainless line. Its like they got a bad crimp or something? Anyone have have an idea if this is fixable of if i should have to buy a whole new hose?
thanks,
ty
notch88 is offline
post #2 of 9 Old 05-03-2009, 09:54 PM
FWIW,I would either make your own(like i did)or buy one from somewhere.I wouldnt bother trying to get another line from QT,cause it would take 6 mos.
Alan VanBuren is offline
post #3 of 9 Old 05-03-2009, 09:58 PM Thread Starter
well i kinda figured that...haha, but he sent me i believe it was a 3/16 in stainless brake line...is this equal to -3 an?
notch88 is offline
post #4 of 9 Old 05-03-2009, 10:08 PM
Yes, each "-x" number indicates 16th of an inch.
mustanggreg is offline
post #5 of 9 Old 05-03-2009, 10:11 PM
I'm not sure.Dont think so.I picked up some -an fittings at a speed shop(-4)with pipe threads where it goes into turbo and oil supply.I know summit or jegs sells some pre-fabbed lines in many sizes.Good luck,ive had to order clamps,make my own lines,etc.Never got any of that stuff.
post #6 of 9 Old 05-03-2009, 10:12 PM
There you go!Someone who knows.
post #7 of 9 Old 05-03-2009, 10:30 PM Thread Starter
ok thanks!
notch88 is offline
post #8 of 9 Old 05-06-2009, 08:37 PM Thread Starter
does anyone know where benard gets his oil feed lines from?
notch88 is offline
post #9 of 9 Old 05-06-2009, 09:20 PM
Not sure where Bernard gets his but race parts solutions sells good lines
http://www.racepartssolutions.com/products.asp?cat=105
T70Cobra is offline
header leak may result in fire! dadslx 5.0/5.8 Engine Tech 3 08-25-2007 03:22 PM
Had a little Elec. fire today 347 Special EEC Tech 1 09-16-2004 04:45 PM
Ahhhh ****.. oil leak in my new car. smurph98gt 5.0/5.8 Engine Tech 10 07-15-2004 06:47 PM
Please help me with my OIL LEAK before i burn my car to the ground 86style 5.0/5.8 Engine Tech 1 05-17-2002 12:54 AM
Can an oil pan leak be fixed while it's on the car? ds94 5.0/5.8 Engine Tech 3 04-24-2002 09:13 AM
