Is this too much loop in my drain hose??? Pic inside - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 05-03-2009, 09:25 AM Thread Starter
Rich G's Avatar
Trader Feedback: (35)
I am getting a ton of smoke from my downpipe area, it was coated @ B&G and then I wrapped it and painted it with the paint yoru supposed to use for wrap.
I am not sure if its just the coating/paint burning in or if its oil backing up into the turbo
I havent seen any boost yet but the smoke was pourign out of the cowl hood
I cant really get it higher because of the sway bar but it only goes up maybe a 1/4"
Any advice is appreciated
Rich G is offline
post #2 of 9 Old 05-03-2009, 10:33 AM
smurfmobile8586's Avatar
Looking at the pic on my phone it does not look like too much of a bend. I would think its the paint stuff when i wrapped mine i jist wrapped it with no paint.
smurfmobile8586 is offline
post #3 of 9 Old 05-03-2009, 10:38 AM
Trader Feedback: (36)
Is there any room to go to the inside of your crossover pipe?
scotng is offline
post #4 of 9 Old 05-03-2009, 10:50 AM Thread Starter
Rich G's Avatar
That pic doesnt really show the routing, actually its the swaybar thats the issue
Rich G is offline
post #5 of 9 Old 05-03-2009, 11:33 AM
saleen9973's Avatar
It looks like it dips just below the fitting on the pan. I would try to run it a little different if you can. Are you set on running a sway bar?
saleen9973 is offline
post #6 of 9 Old 05-03-2009, 11:49 AM Thread Starter
Rich G's Avatar
It does just slightly, is that really that big of a deal?
Rich G is offline
post #7 of 9 Old 05-03-2009, 12:18 PM
that paint will burn for days oil return look fine
Hang Em High Motorsports is offline
post #8 of 9 Old 05-03-2009, 12:41 PM
NC STANG GUY's Avatar
Trader Feedback: (176)
That should be fine. My drain is worse than that and I've had no problems.
Your exhaust will cook for a while. First time you really get it hot with some boost it really will smoke. After it's been heat cycled several times it should be fine and quit smoking.
NC STANG GUY is offline
post #9 of 9 Old 05-04-2009, 04:20 PM
331merc's Avatar
If the oil was not draining out of the turbo it would push the seals of the turbo and leak into the compressor or exhaust housing. If that was the case it would be leaking into the exhaust. And the exhaust would be smoking. Not the exhaust pipes. If you do not see oil on the piping or exhaust housing you should be fine.
The paint needs to get hot a few times to cure. It will smoke for a little bit. My ceramic coating smelled like pancakes when we first started the car. lol After driving it a few times the fumes went away.
Mike 1986 Capri street car w/ a/c, p/s & p/w
Custom built T6 80mm s400sx based kit Shaunthony's built (Twin Trouble and Anthony Fury)
9.31 @ 146 1.39 60' on drag radials @ 3735# Kurgan tuned AEM EMS
80mm 718rwhp new 88mm 921rwhp No new track times yet
331merc is offline
vortech oil drain hose jpe Superchargers 11 04-08-2009 06:38 PM
what hose could this be? pic inside... 91_5.0GT 5.0/5.8 Engine Tech 2 05-13-2007 11:57 AM
Oil drain hose for A-trim??? THUNDER92 Superchargers 5 10-08-2005 10:35 PM
VORTECH Owners...Drain Hose Question! 94GTLaserRC 94/95 Tech 12 08-05-2004 08:31 PM
Oil Drain Hose Leaking 5.0 HO Superchargers 4 05-10-2004 09:25 AM
