Need help choosing a maf for turbo car - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-02-2009, 12:18 PM Thread Starter
spooledupsupra's Avatar
Well I finally got my hands on a notch. It needs some work and its a lot of new stuff to learn for me. Anyway its a 306 with 42 lb injectors and a cartech turbo kit with I believe a 70mm ITS turbo. When I got it it had a draw through lightning maf and the bov open to atmosphere. I know I need to change things around and the car hardly ran before.
I been reading and this is what I am planning on doing. I am going to mount the bov near the turbo and get a blow through maf and mount it in the passenger side fender near the throttle body. What maf do you guys recomend? I was thinking the PMAS pro tube 3in
Here is a small problem though. The piping is 2.5 inch. The maf is 3 inch would it be affected if I stepped up the piping to 3 inch near the maf then back down to 2.5 inch after? I don't know if that will disrupt the air flow causing the car to run weird.
Any help or recommendations would be appreciated.
Cisco
1997 Alpine Silver 6-Speed 74GTS 612 daily whp
1989 Mustang turbo coupe "Project bang for the buck"
1999 Chevy Corvette M6
spooledupsupra is offline
post #2 of 5 Old 05-02-2009, 09:42 PM
WHITEMACH's Avatar
Trader Feedback: (23)
you got it pro tube!!!!this is my cartech ss kit!!! with 3inch pro tube!
WHITEMACH is offline
post #3 of 5 Old 05-02-2009, 10:35 PM
PUR PONY's Avatar
im using a PMAS HPX slot meter in a 3.5" tube. Havnt had a chance to drive the car yet. I had a tuning date setup yesterday but it got cancelled. Using an SCT chip. You can also purchase purchase a 3" or 3.5" housing to install inside of your existing tubing.
-'89 Coupe - Incon Twin Turbo - Sheetmetal Elbow on a EFI Victor-Trick Flow Heads-Viper T56-RXT-Baer Brakes-iforged Wheels-Griggs,MM,KB-DFI-
PUR PONY is offline
post #4 of 5 Old 05-03-2009, 06:05 AM
hotordder_101's Avatar
did you post same topic on turbo forums? anyway all you need to do is get 2 silicone couplers 2.5"x3". get the good ones that are reinforced. my brother went to home depot and found some but they were just to get the car running.
'94 F350 Crewcab dually 7.3 Turbo (Not Powerstroke) Deisel CLEAN
'89 Ranger 2.3 5spd Work Truck
hotordder_101 is offline
post #5 of 5 Old 05-03-2009, 01:23 PM Thread Starter
Yes I also posted it there. Thanks for the reply guys.
Need help choosing ignition for turbo car got9lbs Turbochargers 2 02-11-2009 10:33 PM
Help with choosing a turbo Jimmy_Rawzy Turbochargers 0 09-15-2008 04:12 PM
choosing a turbo billybo455 Turbochargers 13 08-24-2006 01:53 PM
NEED HELP IN CHOOSING THE RIGHT TURBO marc soto Turbochargers 4 11-14-2003 08:04 AM
Need help choosing MAF meter HOtrain 5.0/5.8 Engine Tech 3 05-19-2002 09:15 PM
