Turbo cam recommendations? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 04-30-2009, 07:32 PM Thread Starter
I'm looking to build a stock forged 302 with some afr 185's, systemax II and likely a b&g single turbo kit. Who would you seek advice from on a turbo cam? Is Ed Curtis the man to see?
LS1_ETR is offline
post #2 of 13 Old 04-30-2009, 10:00 PM
just buy a fcam and be done with it
dentfix is offline
post #3 of 13 Old 04-30-2009, 10:05 PM
428GT's Avatar
Mine is from Ed Curtis and I'd buy another one from him. But on the other hand I think you can probably make more than enough power to break the block with that combo and the stock cam.
89 GT--428 Dart Block 9.1:1, AFR 225's, Edelbrock Super Victor EFI ,Bullet Cams turbo cam, Accufab 90mm TB, TH-400, Ultimate Converter, AEM EMS, twin GT4088's
428GT is offline
post #4 of 13 Old 04-30-2009, 10:52 PM Thread Starter
haha that is very very true... I'm going to shop around to see if I can find a mexican roller block. I don't want to buy a dart block right now as it will tie up too much of my funds that I want to use for fuel system/suspension components on the car. If some of the turbo guys chime in with a really good off the shelf cam that works well with a turbo I may do that. I do want the car to have some lope to it though. But I have heard the pre 89 stock cam works really well with a turbo? Correct me if I'm wrong.
LS1_ETR is offline
post #5 of 13 Old 04-30-2009, 11:15 PM
anything that opens the valves . . .
streetfalcon is offline
post #6 of 13 Old 04-30-2009, 11:18 PM Thread Starter
I had a Comp XE 272 in my 95 Cobra but I'm guessing that's really more of an NA cam?
LS1_ETR is offline
post #7 of 13 Old 04-30-2009, 11:34 PM
jman511115's Avatar
Get Ed to grind you one. Not much more than an off the shelf, and it will be better matched to your combo. I've got one, it sounds great and makes plenty of power. I'm at around 420/450 to the wheels on 7 psi and 93 octane.
64,999,987 firearms owners killed no one yesterday.
NRA member and you should be too! It's about more than just the guns. Join here.
https://membership.nrahq.org/forms/signup.asp?CampaignID=FrdmAssoc
jman511115 is offline
post #8 of 13 Old 05-01-2009, 12:00 AM Thread Starter
Yeah kinda what I was thinking. Does he also recommend getting certain valve springs with his grinds? Or just depends
LS1_ETR is offline
post #9 of 13 Old 05-01-2009, 11:32 AM
jman511115's Avatar
Probably depends on how crazy your grind is. I'd get new springs anyways, you're going to be beating on the car and aftermarket springs will take the beating better than stock ones.
post #10 of 13 Old 05-01-2009, 11:53 AM
F-cam. Save the money
91VictorJr is offline
post #11 of 13 Old 05-01-2009, 11:56 AM
klu408's Avatar
Trader Feedback: (18)
If you're wanting to save all the money you can just get the Fcam... Do a search and just see what kind of HP people are making with them!!!
klu408 is offline
post #12 of 13 Old 05-01-2009, 03:37 PM
Trader Feedback: (45)
On the other hand a completely stock motor can make enough power to break the block. Sell me the motor for 200 dollars and I'll give you a stock one.
1989 Ford Mustang Notch 5.0
1979 Ford Fairmont Boxtop (LSX/4.8/Big BW Turbo)
Speedy911 is offline
post #13 of 13 Old 05-01-2009, 10:34 PM
Blackfive0's Avatar
Trader Feedback: (62)
If you really want to spend the money on a cam then I would go with a TFS 1 or a f cam. Other wise I would stick with the stock cam and just set it up -4*
Blackfive0 is offline
Need recommendations for turbo cam Mobile Chassis Dyno Turbochargers 9 05-02-2009 01:04 PM
351w BG CUSTOM TURBO Turbo headers carb, turbo cam,pistons,gaskets,waste gate stang1986 Power Adders 8 03-25-2008 10:55 AM
recommendations for 4.6 turbo kits? vipergts2000 Turbochargers 21 10-16-2006 02:11 PM
Need an "out of the box" turbo cam, any recommendations??? Black Dragon Notch Turbochargers 8 03-20-2003 09:45 PM
