Couple of fitment problems need help with.. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 04-29-2009, 07:02 PM Thread Starter
Ok, so trying to button everything up and am running into a couple things I think are questionable..
#1 For all the A/C users -- the line from the firewall to the condensor is VERY close to the turbo and header, and has to be run under to even make it there. Will this be an issue?
#2 Power steering lines are close (almost touching) the crossover pipe.. what to do with this? Heat tape?
#3 Lower radiator hose is very close to crossover as well. It does not touch the actual pipe, it touches the t-bolt but it's still extremely close. Again.. what to do about this?
ChaseGT is offline
post #2 of 10 Old 04-29-2009, 08:15 PM
rob
rob's Avatar
Trader Feedback: (23)
1. wrap it
2. remove braket and reroute hose in a better spot.
3. trim hose at radiator to pull it closer to rad and away from exhaust.
rob is offline
post #3 of 10 Old 04-30-2009, 09:18 AM
93gtman's Avatar
Trader Feedback: (21)
what kit?
NY
93gtman is offline
post #4 of 10 Old 04-30-2009, 10:05 AM
Originally Posted by 93gtman View Post
what kit?
ditto
post #5 of 10 Old 04-30-2009, 10:34 AM Thread Starter
It is a B&G kit. And I don't think cutting the rad. hose is going to yield any benefit..
ChaseGT is offline
post #6 of 10 Old 04-30-2009, 10:56 AM
87pony's Avatar
if its the stock radiator hose, you can get at least another inch or so of clearance by cutting it.
87pony is offline
post #7 of 10 Old 04-30-2009, 11:04 AM
93gtman's Avatar
i didnt have to cut mine i just ceramic coated the hot side and wrapped the crossover and down pipe no problems and i have about 3 inch between the crossover and the loser hose.
as for the AC line i had a custom one made
NY
93gtman is offline
post #8 of 10 Old 04-30-2009, 12:05 PM Thread Starter
Where do I go about cutting it? Also, do you have pics of that custom A/C line? I guess I'll buy some more wrap and do the crossover as well, but I'm not doing the headers as I will get them coated eventually.
ChaseGT is offline
post #9 of 10 Old 04-30-2009, 12:46 PM
93gtman's Avatar
let me see if i can dig one up for ya
NY
93gtman is offline
post #10 of 10 Old 04-30-2009, 02:55 PM Thread Starter
Thanks!
ChaseGT is offline
Hellion fitment problems..... LilMayo Turbochargers 15 12-04-2005 07:46 AM
Header fitment problems Billaird's86GTvert 5.0/5.8 Engine Tech 0 04-15-2005 09:19 PM
BBK LT fitment problems Stylin97 aka 97-V6 94/95 Tech 7 07-24-2004 12:21 AM
If you've had fitment problems with dr. gas xsivpwr 94/95 Tech 0 09-25-2003 05:13 PM
T-5 / Crossmember fitment problems Matt W General Mustang Tech 4 03-04-2003 03:11 PM
