Going To The Dyno Saturday - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 04-24-2009, 07:50 AM Thread Starter
Meangrn92GT's Avatar
Trader Feedback: (62)
Going to the dyno Saturday and depending how it does there I might be going to the track right after. What type of power should this car be making? To ME it feels slow on the street but I guess that's what the dyno/dragstrip is for to be sure. Anyways, here is the combo:
302
TFS TW heads
Stock Cam
1.72 Rockers
Exploder Intake
Stock TB
Hellion kit with MP T70(.68 exhaust housing) making 10psi
#42 injectors
BA2400 MAF
GSS340 pump
The car is on a Bob Kurgan mail order tune that has 18* of timing in it currently and the AFR's are in the low to mid 11's under boost. Car is a manual(stock T5 ftw) and has straight through mufflers etc etc, nothing really there that should restrict power. What are your guesses power wise, I'm not super worried about ET at the moment because the car is just now getting some suspension and it'll be on nitto DR's. Just looking for a good figure in the MPH department but it just doesn't feel "strong" on the street to me. Opinions?
-Dave
1992 Mustang GT
Meangrn92GT is offline
post #2 of 13 Old 04-24-2009, 08:18 AM
double check them timing set at 10deg BTDC... i say 440rwhp for now
PLEASE EMAIL --->
<--- DO NOT PM for prices or tuning!
815-669-RACE (7223) <--- Sales
Please visit our e-store --->
Chicagolands largest Vortech dealer since 2006!
We stock many parts! If you dont see it, just ask!
Before you buy ANY mustang part, give us a chance. We accept mastercard and visa.
Authorized SCT, AEM, Diablosport, Vortech, Paxton, BS3, FAST, UPR, PA Racing, Harland Sharp, Team Z, GMS, Trickflow, Kooks, and MANY MORE!
flyin_hawaiin is offline
post #3 of 13 Old 04-24-2009, 08:20 AM
millhouse's Avatar
500rwhp give or take....although you could get more with some extra timing thrown in (not that you need it on the stock block).
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #4 of 13 Old 04-24-2009, 12:34 PM Thread Starter
Good lord, you all really think it'll be that high? It sure doesn't "feel" it on the street. I raced a buddies turbo 2v and it didn't go well for me up top and his car was making 440-450rwhp. I will admit if the car makes 440rwhp I'll be beyond happy!
Thanks for the suggestion on checking the timing Bob, I'm going to do that and double check all hose connections/fuel pressure/etc. Hopefully I'll report with 400+rwhp numbers tomorrow!
-Dave
1992 Mustang GT
post #5 of 13 Old 04-24-2009, 01:47 PM
millhouse's Avatar
I’m running 2lbs less boost (although with more timing) through a similar combo and laid down damn near 500rwhp. Of course, there are many variable which could sway the numbers in one direction or another…and you really need to run down the track a few times to verify what the dyno is telling you regardless.
Are you sure the reason you don’t “feel” it isn’t because your spinning the tires into oblivion?
post #6 of 13 Old 04-24-2009, 04:04 PM Thread Starter
I'm not sure Millhouse but he sure pulled on me pretty good and I would think my fox would weigh less than his car. I do plan on going to the track right after the dyno just to see how the numbers match up, it probably won't trap much over 110mph based on how it "feels".
Turbos do have an odd pull though, we'll see! Thanks guys!
-Dave
1992 Mustang GT
post #7 of 13 Old 04-24-2009, 06:45 PM
millhouse's Avatar
I'm with ya. Something similar happened to me a month ago....and it turned out to be an coupler blew off leaving me with 3lbs of boost! Good luck!!!!
post #8 of 13 Old 04-24-2009, 07:09 PM
jturmanator's Avatar
Id say under 450hp.
jturmanator is offline
post #9 of 13 Old 04-26-2009, 09:13 AM Thread Starter
Well took it to the dyno and to the track, here are my results. Looks like I was pretty close on the guesses.
Car made 395hp and 530trq, power peaked at 4250rpm and torque was at 3650rpm. Air Fuel is in the upper 10's up top so I'm guessing I'll have to have the car leaned out a lot up top for the peak power to raise. Took the car to the track right after the dyno and only made one pass, missed second gear and ran a 14.38 @ 108.xx mph. Probably should of went again but after the dyno the plugs were shot, so there is always next time.
Now, based on the car making 395 at 4250, what are some realistic goals that the car can make with the correct air fuel? I think I want to be in the 450-475rwhp range, may have to up the boost some but I'm ready for it. It just felt good getting to drive the car over the weekend, first time it's been on a trip of any sort in 3 years.
Graph(Sorry it's hard to read, even in person):
-Dave
1992 Mustang GT
post #10 of 13 Old 04-26-2009, 09:33 AM
red89coupe's Avatar
Trader Feedback: (31)
wow it should have WAY more then 110mph in it !!! I run STOCK motor on 10 psi and trap 120-122 mph. double check everything just to be sure something "little" isnt messing ya up. numbers seem way low for that combo... to me anyway.
if you have plugs gonig bad then there is a issue, with a good tune you can run the same plugs for months with no worries.
red89coupe is offline
post #11 of 13 Old 04-26-2009, 10:24 AM
now that we have some good info, send the chip back so i can lean it out a bit and give it the timing it really needs... i dont see picking up 60-75rwhp out of the question.
PLEASE EMAIL --->
post #12 of 13 Old 04-26-2009, 11:14 AM Thread Starter
Indeed the numbers are low for the combo, but considering the issues I think it just shows the potential is there.
Bob, I got a video of the wideband and had a buddy video the boost gauge and tach from the backseat, so I plan on sending you those two videos with the chip back asap. I'll e-mail you with some more info and questions to see what you think. Even though the car was so rich I still put 250ish miles on the car without a single issue, minus a little worse fuel mileage than normal from all the hard pulls on the car.hehe
-Edit-
E-mail sent Bob!
-Dave
1992 Mustang GT
post #13 of 13 Old 04-26-2009, 11:28 AM
mbricher's Avatar
Congrats on the new numbers! Once Bob tweaks the tune for you it should pick up quite a bit.
1990 Mustang GT
Dart IE 363, PT78 HPS, Built 4R70W, BS3, BBRC Fuel system, TeamZ, ect.....
Tuned by Bob Kurgan
mbricher is offline
Off to the Dyno on Saturday...HP predictions? CRFrider16 5.0/5.8 Engine Tech 14 08-06-2006 07:30 AM
Novi 2000 Dyno-Tune this Saturday - Predict My Paxton chip #s vs Dyno-tune #s! 00whiteGTvert GT & SOHC 161 02-04-2003 12:19 PM
Went to the dyno on Saturday... 01blownGT GT & SOHC 16 06-13-2002 05:00 PM
Getting a dyno tune on Saturday... LAST302 94/95 Tech 2 03-13-2002 02:37 PM
