Need recommendations for turbo cam - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 04-20-2009, 11:24 AM Thread Starter
R302 (Has cam roller bearings)
Valvetrain is Hydraulic Roller
Ported Twisted Wedge Heads
Short Runner Manifold
PA C4 tranny w/brake
Looking at doing a 88mm turbo.
Motor was built to NMRA real street specs with a S Trim. The heads are off being ported and I figured now was a good time to slide a cam in.
What are some of the popular companies that specialize in small block ford turbo grinds?
Does Ed Curtis at Flowtech do any turbo grinds?
Please discuss.
Brian Turner
4 Mustangs and a Z06
Mobile Chassis Dyno is offline
post #2 of 10 Old 04-20-2009, 01:09 PM
montelius's Avatar
Trader Feedback: (31)
https://forums.corral.net/forums/show...lift+turbo+cam
This thread may also be helpful.
http://www.turbomustangs.com/smf/ind...?topic=28415.0
Luke M.
montelius is offline
post #3 of 10 Old 04-20-2009, 02:35 PM
fred50stang's Avatar
I have a comp cam grind. Seems to work decent. Pulls 16lbs of vacuum at idle.
fred50stang is offline
post #4 of 10 Old 04-20-2009, 10:37 PM
WHITEMACH's Avatar
Trader Feedback: (23)
job spetter jr,,,,AAAAA+++ that is if you want to go real fast!!
WHITEMACH is offline
post #5 of 10 Old 04-21-2009, 01:13 AM
XJHEAD's Avatar
I have a Ed Curtis cam in mine.
See below.
Fastest Ethanol Powered Street Car in the World
SN-95 7.64 @ 187 315 Radials E-98
TT 427 TH-400 3400 lbs.
Baseline Supsension, Ed Curtis
XJHEAD is offline
post #6 of 10 Old 04-22-2009, 09:18 PM
xjhead do have a hydraulic or soild roller cam
94 GT Edelbrock heads Holly Systemax 2 intake Steeda 19 cam TKO 500 Spec 2 clutch
fish254 is offline
post #7 of 10 Old 04-22-2009, 10:55 PM
XJHEAD's Avatar
Solid roller, maintanance isn't as bad some make it sound. Everytime I checked them they were right on.
XJHEAD is offline
post #8 of 10 Old 04-23-2009, 01:10 PM
MIKE92NOTCH's Avatar
f cam will also do the job. jay allen also does a great job with turbo cams. but you better upgrade from that c4 based on the power levels you could be making.
95 Crystal White GT
8.50 chassis with a 12 something drivetrain
MIKE92NOTCH is offline
post #9 of 10 Old 04-26-2009, 12:26 AM
Angry_Man's Avatar
I had Jay do a new grind for my incon car to replace a custom cam my builder had ground. I am very pleased with the new cam. Best money spent so far as $/hp for my application.
Do roller cam bearings require a billet cam?
Angry_Man is offline
post #10 of 10 Old 05-02-2009, 01:04 PM
Will Evers's Avatar
Yea, call the shop. You will probably talk to Chase, but Job will have one made to his specs for you.
I have one of Job's in my car now.
You can go as fast as 8.60s with the hyd roller but I wouldnt recommend it.
Will Evers is offline
351w BG CUSTOM TURBO Turbo headers carb, turbo cam,pistons,gaskets,waste gate stang1986 Power Adders 8 03-25-2008 10:55 AM
recommendations for 4.6 turbo kits? vipergts2000 Turbochargers 21 10-16-2006 02:11 PM
cam recommendations CobraVnm 5.0/5.8 Engine Tech 3 12-26-2003 12:27 AM
Need an "out of the box" turbo cam, any recommendations??? Black Dragon Notch Turbochargers 8 03-20-2003 09:45 PM
