Stock guages with DFI or carb? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 04-17-2009, 09:02 AM Thread Starter
I am installing my DFI and wondering if anyone knows easy ways to get the oil and temp guages to work. I think I can figure the tach out but I would like a short cut if anyone knows.
Renfro is offline
post #2 of 15 Old 04-18-2009, 11:59 PM
my8950's Avatar
DFI doesn't have anything to do with the oil or temp gauge....
Its got its own temp sensor, and doesn't care about oil pressure.
my8950 is offline
post #3 of 15 Old 04-19-2009, 11:32 AM Thread Starter
You missed the question. I have removed the stock harness and stock computor. All the wiring for the temp and oil run in the stock ECU harness.
Renfro is offline
post #4 of 15 Old 04-19-2009, 11:41 AM
XJHEAD's Avatar
http://www.veryuseful.com/mustang/te...nt-Cluster.gif
Fastest Ethanol Powered Street Car in the World
SN-95 7.64 @ 187 315 Radials E-98
TT 427 TH-400 3400 lbs.
Baseline Supsension, Ed Curtis
XJHEAD is offline
post #5 of 15 Old 04-19-2009, 12:19 PM
my8950's Avatar
how would anyone know, help us help you by telling us what you're working on.
my8950 is offline
post #6 of 15 Old 04-19-2009, 12:28 PM Thread Starter
lol I thought it was common knowledge that the only good mustangs were 87-93's. Sorry, I took it for granted that everyone has read my on 3 install thread.
Thanks XJ this will help. I wonder if these gauges or 5 volt refrence or 12?
Renfro is offline
post #7 of 15 Old 04-19-2009, 12:37 PM
XJHEAD's Avatar
If you power up the cluster all sensors provide a resistance signal through sensor to ground. So they are 12 volts. Only sensors that are 5volts are the ones powered by the ecu. At least that is my understanding.
ps. 94-95 are the best ones..
XJHEAD is offline
post #8 of 15 Old 04-19-2009, 12:40 PM
my8950's Avatar
Actually, if its an 87-93, then the gauges on the cluster are not run by the EEC.
Oil pressure is red with a white stripe, coolant is red with a blue stripe...
my8950 is offline
post #9 of 15 Old 04-19-2009, 03:16 PM Thread Starter
They are in the ECU harness I removed.
Renfro is offline
post #10 of 15 Old 04-19-2009, 03:28 PM
my8950's Avatar
They are routed through the underhood/EEC harness. No you've got 2 open ends, one on the gauge and one on the sender, fill in the blank in the middle and they'll work.
The EEC doesn't care if you have oil pressure or not, therefore its not critical to the function for the EEC. Coolant has another sensor, one for the EEC and one for the gauge.
What year is the car? You need an ETVM....The listed website has a ton of info, and was very good for resources when I did mine, and the next, and the next...I've done quite a few cars and go through the same sequence every time...
my8950 is offline
post #11 of 15 Old 04-19-2009, 04:21 PM Thread Starter
I got it all figured out. It was so simple a cave man could do it. I never had looked at it before. I thought the sensors also ran through the ECU before they got to the gauges. Cool to have them all working now. Thanks for the help.
Renfro is offline
post #12 of 15 Old 04-19-2009, 08:32 PM
So what your saying is that when I go to install my FAST system in my 1991 that I can just run wire from the sensor to the dash and it will work fine?
got9lbs is offline
post #13 of 15 Old 04-19-2009, 08:49 PM
XJHEAD's Avatar
For the dash guages yes.
XJHEAD is offline
post #14 of 15 Old 04-19-2009, 10:02 PM
my8950's Avatar
See, and I bet that before you looked at it, and read my post you thought I was giving you sh*t....
Not really though, its that easy...
my8950 is offline
post #15 of 15 Old 04-20-2009, 09:06 AM Thread Starter
No, it is easier than that. On the two plugs by between the wiper and strut tower, on the black connecter, the temp and oil are right there. Just two wires. Red/white and white/red. There was a green/yellow in the grey connnector that works the tach. I can't believe it was this simple. I remember installing my first DFI years ago and hating to add gauges. I can't believe I missed this. It is a cool deal.
Renfro is offline
$$$$ Dropped Prices Carb.roller rockers t bodyvalve covers guages $$$$ bonz Windsor Engine Parts 19 10-04-2008 02:44 PM
S.D.S DFI and stock wiring harness f/s or f/t aaron427 Electronics and Entertainment 6 02-08-2004 11:00 PM
White face guages stock on my 96? O.D. Showtime SVT & DOHC 2 09-11-2002 12:18 AM
4 cyl EFI to carb 302. Can I still use my factory guages? Jon89 5.0/5.8 Engine Tech 3 06-05-2002 07:49 AM
