advice on tuning EEC - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 04-14-2009, 07:51 PM Thread Starter
94saleengtvert's Avatar
i have a EEC-tuner on the car in my sig, i have a basic understanding on how to use it and have adjusted the injector size and MAF transfer function seemingly correctly as well as some other minor stuff (turned off the smog, etc.)
i have 2 questions;
1. it's running way too rich, even at idle its enough to choke you out. And the little time (5-10 miles total) that i've driven the car since the turbos, it's rich enough that it stumbles badly at anything short of 3/4 throttle. prior to having the intercooler piping finished i had driven it with the stock maf and injectors obviously running zero boost and it was still running rich, so i dont THINK it's from me modifying the injector and MAF in the EEC incorrectly, but its a possibility. what are some typical mistakes i might have made?
2. When i get the fuel issue worked out, what should i do about timing?
what i'm asking is; what function in the EEC-tuner should i use to pull timing out and how much? i've heard 1 degree per psi but just wanna get opinions.
thanks guys
96 Cobra: 5.0 swap, T5, On3 67mm BB turbo, Megasquirt, EDIS,
94saleengtvert is offline
post #2 of 3 Old 04-14-2009, 08:24 PM
Is your tune a .bin? I don't no how eec tuner works.
on tweecer you can 55 most spark tables and just use one for the spark. 55 means it will ignore it.
can u log with it too?
1994 Turbo GT
mustangless is offline
post #3 of 3 Old 04-16-2009, 10:14 AM Thread Starter
yes there a .bin file. im not positive on what your saying with the spark tables, do you mean you the tweecer ignore it so it runs like locking the timing with the spout out?
EEC-IV Tuning 101 Antiraid EEC Tech 2 12-13-2006 10:14 PM
Best place for EEC tuning? jesseh306 94/95 Tech 1 04-19-2004 07:48 PM
twin turbo 331 needs tuning, which tuning device?? tweecer and eec tuner guys please tording 5.0/5.8 Engine Tech 3 01-24-2004 02:55 PM
Any good books on EEC tuning (or understanding EEC?) Chris Doss SVT & DOHC 14 09-22-2002 02:15 PM
Any good books on EEC tuning (or understanding EEC?) Chris Doss GT & SOHC 0 09-12-2002 01:59 PM
