Electric Fan pusher or puller? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 04-13-2009, 09:27 PM Thread Starter
I put in my new radiator in tonight a 2-core aluminum radiator made here in town (only cost $200!) tried to mount up my flex a lite puller fan and its too thick. It is running into my intercooler piping. I was thinking about ordering the same fan but as a pusher and mounting the fan between the intercooler and the radiator. Its a 2500cfm fan will this be enought to cool my street car down? How well does a pusher fan work?
Maximum Fan CFM: 2,500 cfm
Fan Quantity: Dual
Fan Diameter (in): 12.000 in.
Height (in): 15.500 in.
Width (in): 26.250 in.
Thickness (in): 2.625 in.
Number of Blades: 10 blades per fan nylon
Amp Draw: 19.50 amps
[IMG][/IMG]
The other option is this fan
[IMG][/IMG]
16” High-performance engine cooling in a LOW PROFILE package
2,500 cfm air flow
More Powerful Motor, Only 3-3/16” Deep!
replaces clutch fan ass’y
increases gas mileage
quicker A/C response
quicker warmup
quicker cool down
18.5 amp draw
Size: 16-1/2” x 16” x 3-3/16”
got9lbs is offline
post #2 of 10 Old 04-14-2009, 09:18 AM
93gtman's Avatar
Trader Feedback: (21)
2,500 cfm is not enough i would go with a Tauras Fan or Mark VIII they do about 3,800-4,500 cfm .Baskin on here sells them with a DCC controller i have one of the MarkVIII Fans and it works great on my turbo setup with AC and all ACC
NY
93gtman is offline
post #3 of 10 Old 04-14-2009, 09:31 AM
If you can modify it to fit I would also suggest the Mark VIII fan setup. A shroud that covers the full surface area is a great help in keeping setup cool and driveable in all conditions.
For Sale: 31 Spline Superior Axles 99-04 Length for 8.8 used.
For Sale: 8.8 3.73 Gears used.
For Sale: Spec 3, 10 spline clutch disc used, no pressure plate included, just disc.
For Sale: Pistol Grip shiftknob with switch on top used.
Goodlife is offline
post #4 of 10 Old 04-14-2009, 01:28 PM
WHITEMACH's Avatar
Trader Feedback: (23)
us a 94-95 mustang gt fan !!
WHITEMACH is offline
post #5 of 10 Old 04-14-2009, 08:49 PM Thread Starter
I don't think Im gonna have room for the mark VIII fan, I only have 3 7/8" room from the radiator to the tip of the waterpump shaft. How thick is the that fan? I tried to fit my stock 4.6 fan on there and there is not enought room
pictures of 4.6 fan
[IMG][/IMG]
[IMG][/IMG]
Picture of the flex a lite 220 that hits the intercooler piping
[IMG][/IMG]
got9lbs is offline
post #6 of 10 Old 04-14-2009, 08:59 PM
pennex1's Avatar
If cost is not a issue. The twin BeCool fan is the best fan out there.
http://store.summitracing.com/partde...5&autoview=sku
Dart 347, High Ports, FAST XFI, TH400, Precision 78GTS,E85, 836hp 714tq.
pennex1 is offline
post #7 of 10 Old 04-14-2009, 10:56 PM
Novi357's Avatar
Those are made by spal. You can get them way cheaper than what be-cool is charging for the exact same fan.
Just go on ebay and search under spal dual. Searching under spal 11 also brings up a bunch of them.
Novi357 is offline
post #8 of 10 Old 04-15-2009, 09:50 AM
privatejoker's Avatar
I use a thin Spal Busch series take-off, you might look into one of those.
privatejoker is offline
post #9 of 10 Old 04-15-2009, 09:55 AM
Authorized corral.net Commerical Poster - Exp 4/2010
RealStreetPerformance's Avatar
The best path!
RealStreetPerformance is offline
post #10 of 10 Old 04-15-2009, 12:46 PM Thread Starter
how thick is a 94-95 fan?
got9lbs is offline
Fan ?'s, pusher or puller? nmerrill General Mustang Tech 2 01-30-2008 01:21 AM
Mark VIII Fan pusher or puller? kwikstang General Mustang Tech 5 08-26-2006 04:49 AM
stock 94/95 electric fan - puller or pusher? Cobra Jet NJ 94/95 Tech 3 07-20-2006 08:33 PM
Pusher AND puller fan??? LXRACR 5.0/5.8 Engine Tech 3 08-14-2002 04:11 PM
puller or pusher fan and why? wesb General Mustang Tech 4 06-24-2002 09:52 AM
