cheap idea for upper rad. pipe - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 04-12-2009, 10:21 PM Thread Starter
Ok so most of us normally have to put one of them fancy vortech upper radiator pipes on when we turbocharge or supercharge our stangs...well i wasnt willing to pay that much just for a stupid pipe. Im not sure if some of you have already figured this out or not, but i just thought i would share the idea to save everybody a little bit of dough if they have to go through what i did! I went to the auto parts store and bought the cheapest rad. hose i could find with two decent 90* angles on it that i can cut off. I went with the 1 1/2in on both ends. Then i took an old piece of alum. fuel line and cut it to the length i thought i needed the pipe to be and bent it easily by hand to the curves i thought it needed. I just took the alum fuel line piece i bent up to a muffler shop and had him bend me a piece of aluminized 1 1/2in pipe equal to the piece i mocked up. Heres a pic! it worked great and i even took a scotchbrite pad to clean up the look of the pipe. I was very happy with the results and the rad. hose cost me 15 bucks and the pipe only cost 4 bucks!!
notch88 is offline
post #2 of 9 Old 04-13-2009, 04:27 PM
nmcgrawj's Avatar
good stuff
-Nate
'95 GT
nmcgrawj is offline
post #3 of 9 Old 04-13-2009, 06:20 PM
Awesome idea, I will probably do that.
ChaseGT is offline
post #4 of 9 Old 04-13-2009, 07:01 PM
hbk_136's Avatar
Trader Feedback: (62)
nifty AND thrifty, i like it.
96 Triple Black GT Vert Supercharged -- 401rwhp / 394rwtq
Vortech V1 S-Trim @ 10psi--2003 PI Engine--36# injectors--90mm L-MAF--AFM PowerPipe
Accufab Plenum + 70mm TB--BBK LT's--MAC O/R Prochamber--Magnapaks
F+R 13" Brakes--3.55's--255lph Pump & T-Rex--Snow Stage 2 Meth Kit
hbk_136 is offline
post #5 of 9 Old 04-13-2009, 08:17 PM
D O A's Avatar
That is cool, I'm doing it!
88 Notch. QT PT 6776 turbo kit, Edelbrock RPM, Cometic, Crane 1.6, f303, LW bell, 6 pt., 3.73, strange adj. 6AL, MB Jr. upper/lower control arms, T5-Z, SRP pistons, main support, windage tray, FAST XFI, Strange spool & 33 spline axles, c-clip, Spec III, Flaming River man. rack, Team-Z anti-roll
D O A is offline
post #6 of 9 Old 04-21-2009, 02:24 PM
I just cut like 6 inchs from the end of the hose off, and no it is just at a 45* angle
ramsey is offline
post #7 of 9 Old 04-21-2009, 03:14 PM
ratedz's Avatar
Great post - i'm doing this soon. Thanks for the info!
1986 Mustang GT
525hp/626tq
ratedz is offline
post #8 of 9 Old 04-21-2009, 07:09 PM
1995gtCPE's Avatar
Trader Feedback: (34)
Might want to see about welding a bead around the ends so the 90's dont blow off.
1995gtCPE is offline
post #9 of 9 Old 04-21-2009, 07:22 PM
+1
500dollar744ti is offline
