Custom Single Turbo setup - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 04-09-2009, 10:21 PM Thread Starter
Finally getting a start on my single turbo kit for the 1991 notchback I bought last year. Car is my DD in the summer, 1991 5.0 auto with 177k bone stock. Currently installing a custom single kit, tko 600 , classic FAST system and a few suspension mods and rearend work. For the turbo kit I'm using a pony down hotside, and my own custom 3" coldside piping. I have the entire coldside tacked together but I have a small decision to make about joining the pipe between the fender and the TB. I have two options:
A) Use a v-band to join the pipe in the fender and the TB pipe, would look clean and make it easy to take pipe off to change spark plugs. Problem is that Im not sure that the v-bands can be used on the pressure side, are they airtight like a silicone sleeve?
B) Install a silicon sleeve as you see in the pictures below, have one t-bolt in the fender and one in the engine bay. I am leaning towards this method, but want to see what you guys think.
I will come back and update this thread as things progress.
[IMG][/IMG]
[IMG][/IMG]
got9lbs is offline
post #2 of 11 Old 04-09-2009, 10:58 PM
I'd go with the silicone sleeve. I wouldn't trust a v-band assembly to hold boost as much as I would a silicone sleeve.
SonicFox is offline
post #3 of 11 Old 04-09-2009, 11:33 PM
nice work, if you want to get trick you can use a wiggins clamp
http://www.burnsstainless.com/Hardwa...insclamps.html
DR.GRIP is offline
post #4 of 11 Old 04-10-2009, 09:38 AM Thread Starter
Wow good thing I was sitting down! Those clamps are $208 each, I'll just stick to the silicone and t-bolts. I will say they are slick looking!
got9lbs is offline
post #5 of 11 Old 04-10-2009, 11:06 AM
-venom-'s Avatar
Wow those are sweet clamps but pricey.
-venom- is offline
post #6 of 11 Old 04-10-2009, 11:17 AM
Nothing wrong with V-bands on cold side.
Yes they will seal. Much better than silicone couplers.
Check out cold side pipes on some Pro-stock turbo cars sometimes.........
Couplers give the system somewhere to flex, so you do need some
but a V-band isnt going to "blow off" like a coupler.
r.barn is offline
post #7 of 11 Old 04-10-2009, 11:26 AM
yeah they are up there, ive seen them on ebay for 45 dollars, but i dont know how the quality is.
DR.GRIP is offline
post #8 of 11 Old 04-10-2009, 10:14 PM
STANGFREEK94's Avatar
Trader Feedback: (27)
I got V-bands from these guys. They are very nice. Had a tounge and groove receiver type setup. 1 side has a groove, the other has a lip that sits in the groove for perfect alighnment. This was @ 1.5 years ago. But, you can call and ask them if they still have that type. I used it on my hot and cold side. No issues what so ever.
http://racepartsolutions.com/products.asp?cat=106
1994, 347, 78mm, alot, NO-you can't!
STANGFREEK94 is offline
post #9 of 11 Old 04-11-2009, 04:57 PM
PUR PONY's Avatar
im building my new intake pipe today and am using a racepartssolution v-band on my pressure side. It has an o-ring for holding pressure. Ill post pics later.
-'89 Coupe - Incon Twin Turbo - Sheetmetal Elbow on a EFI Victor-Trick Flow Heads-Viper T56-RXT-Baer Brakes-iforged Wheels-Griggs,MM,KB-DFI-
PUR PONY is offline
post #10 of 11 Old 04-11-2009, 05:03 PM Thread Starter
hmm shoot me a link if you dont mind
got9lbs is offline
post #11 of 11 Old 04-11-2009, 06:24 PM
PUR PONY's Avatar
here is a pic of what i have tack welded together so far. Hope to finish it up tonight.
finished it up last night-
PUR PONY is offline
MMR Custom Turbo Cams for 2V, 3V and 4V Mod Mustang Racing Modular Engine Parts 183 10-18-2016 11:24 PM
Maybe WTT Turbo Setup for Blower Setup Killa93Hatch Power Adders 4 04-18-2009 08:54 PM
my custom fuel line setup, keeping the hardlines Stylin97 aka 97-V6 94/95 Tech 15 04-17-2009 11:07 PM
remote turbo setup, anyone have one on a fox? uchi Turbochargers 22 04-04-2009 07:36 PM
WTT CCW 505As with tires and Aftercooled vortech for 96-98 complete turbo setup ljinx23 Power Adders 13 03-19-2009 10:40 PM
