My BG Turbo Kit install - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 80 Old 04-06-2009, 06:10 PM Thread Starter
Rich G's Avatar
Trader Feedback: (35)
My kit came in today, not gonna do a huge build thread but figured I would show some pics I know people like to see them.
Box of stuff
Started install
So far so good, no real complaints so far but the coating is pretty cheap it seems, scratches super easy and it wasnt completely even.. Cant complain considering it was a fairly cheap upgrade but would prefer better, maybe when I blow this motor I will have it jet-hot or something else.
Couple things
1) Had to move my clutch cable, stock would probably work but I had the extended clutch cable, not sure where I am going to put it yet.
2) Had to remove my charcoal box, definatly will need to find a place to put it as I cant go without it.
3) Had to trim the sway bar mount pretty heavily, not a big deal and expected it.
4) I have to make my own intercooler brackets, not too happy about that but its easy enough to do
Rich G is offline
post #2 of 80 Old 04-06-2009, 06:22 PM
saleen9973's Avatar
What kit is that?
saleen9973 is offline
post #3 of 80 Old 04-06-2009, 06:24 PM
saleen9973's Avatar
I am dumb a$$ i see the heading.
post #4 of 80 Old 04-06-2009, 06:35 PM
1994 Turbo GT
mustangless is offline
post #5 of 80 Old 04-06-2009, 06:42 PM
RwbMstng's Avatar
I like the B&G Kits.. I still would like to see them with an intercooler similar to the ones on the HP kits.
RwbMstng is offline
post #6 of 80 Old 04-06-2009, 06:45 PM
Looking good. What is the type of coating upgrade you opted for?
SonicFox is offline
post #7 of 80 Old 04-06-2009, 07:26 PM
NoSloCoupes's Avatar
Trader Feedback: (53)
Nice. Just finished up my install this past weekend. Don't see why you had to grind so much off the swaybar mount...unless the engine is cocked to the dr side, which would give you a LOT of room on the pass side. I'm using solid mounts, didn't grind the sb mount or need any clearance on the pass side pinch rail. I tucked the intercooler nicely under an lx bumper(only needing to trim the fiberglass headlight panel) but had to shorten the cold side to the cooler about 2" because of this. I also had to take about an additional 2 1/2" off the cold side to the tb....plus the 4" out for the mass air meter. Overall great kit and fitment...except the downpipe, which i did need to break out the BFH on the lower firewall/floorpan area to get it to fit. Seems quite a bit of people need to do this tho.
Still waiting on a y-pipe i ordered from Ponydown tho....should have been here by now! I should have just made one like i planned.
I have the long clutch cable, routed it straight out and around the oil filter area...plenty of room. Drilled the cable bracket and attached it to the ps delete bolt.
NoSloCoupes is offline
post #8 of 80 Old 04-06-2009, 07:29 PM Thread Starter
Rich G's Avatar
Upgraded to the black ceramic coating
Rich G is offline
post #9 of 80 Old 04-06-2009, 07:45 PM
Trader Feedback: (43)
why is there a number 2 circled on the header?
Precision 67mm turbo, this and that.
Thewhite88pony is offline
post #10 of 80 Old 04-06-2009, 07:48 PM Thread Starter
Rich G's Avatar
Thats from it just touching the swaybar mount, thats what I was saying about the coating, it scratches instantly
Rich G is offline
post #11 of 80 Old 04-06-2009, 08:47 PM
nice setup
cool mine will be here next week from b and g
New Setup: 5.0 Coyote Swap, LTs, JLT, Tune. 435 rwhp 419 rwtq. 11.365 @ 121mph on NT05.
Old Setup: 306 forged bottom end, stock gt40 heads, 1.7s stock cobra intake, e- cam and bolt ons 275rwhp and 315 rwtq on a break in tune
sneaky94cobra is offline
post #12 of 80 Old 04-06-2009, 10:56 PM
Bobo's Avatar
Nice pics. My buddy has Jet hotted his Cartech kit....and it's been flakey :-/
Oh btw, what header bolts did you use? Brian told me what bolts I needed to get for my kit, but of course I proceeded to forgetting.
Scotty we need more power!!!
Bobo is offline
post #13 of 80 Old 04-07-2009, 12:33 AM
jonyboy107's Avatar
Trader Feedback: (15)
did that air filter come with the kit?....
Thanks for taking the time to post
DAILY DRIVEN: 92 GT
306,9,5:1,AFR 185s,RPMII,xe264hr,ProMagnum rockers,turbonetics 66S,bg kit,METH,Flowmaster catback,Accufab race 75mm,pro tube,60lb injectors,255lph walbro BAP,ac delete,no smog,full MSD ignition,mark fan,3G alt,TKO600,spec stage 3,alum flywheel,3.55s
jonyboy107 is offline
post #14 of 80 Old 04-07-2009, 05:17 AM
Looks great so far. My box is sitting in the garage and has been for two weeks. I will unwrap it all when I get home in a few days and get some pics. Hopefully the install will start next weeks, hopefully.
kbscobravert is online now
post #15 of 80 Old 04-07-2009, 05:52 AM Thread Starter
Rich G's Avatar
Yes
Rich G is offline
post #16 of 80 Old 04-07-2009, 05:53 AM Thread Starter
Rich G's Avatar
I just have arp bolts, not sure which ones I have had em forever
Rich G is offline
post #17 of 80 Old 04-07-2009, 07:47 AM Thread Starter
Rich G's Avatar
I did take a BFH to the firewall floorpan ahead of time expectign this issue, its a real pain to get in but once its in it seems to clear everything. Just a matter of getting it hooked to the turbo before tightening the turbo down.
As far as grinding down the subframe, my engine has always sat a little crooked in the bay, so this weekend I spaced out the motor mounts to get the engine to sit level. I have a ton of space on the passenger side, the instructions said to move the pinch weld for the flange and my flange is like a half inch away. Would prolly be better if it was still crooked but I prefer the engine sit straight and have to grind the sway bar mount.
I am ordering some stuff today.
Anyone know how much heatwrap I should order for the downpipe?
They make 4 kits
1" wide x 15' long
1" wide x 50' long
2" wide x 15' long
2" wide x 50' long
I doubt the 15' will be long enough, but should I order the 2" wide or the 1" wide?
Rich G is offline
post #18 of 80 Old 04-07-2009, 09:45 AM
ratedz's Avatar
Fairly straightforward install on this kit - much like my QT kit. I helped a buddy install his BG kit and we didn't have many issues with it - the 3.5" DP was tricky and we had to cut the pipe from the intercooler toTB in order to install the MAF.
All in all it's a nice kit and Brian does a good job with it.
I'll tell you what tho - I can't believe how much hacking the front bumpers need on the aero cars, on my 86 all of the cutting for the intercooler was done behind the bumper - the LX/GT front aero nose - OMG you have to HACK the #### out of it and it's plainly visible from the front so take your time and try to make the cuts look the same on both sides.
That's not just the BG kit, I hear most of them need this surgery.
Good luck!
1986 Mustang GT
525hp/626tq
ratedz is offline
post #19 of 80 Old 04-07-2009, 11:55 AM
I wrapped just the downpipe from the turbo, to where it turns down at the firewall. I ordered the 2" x 50' and used less than half of it. I wasn't sure how much I was gonna wrap when I ordered it.
They make 4 kits
1" wide x 15' long
1" wide x 50' long
2" wide x 15' long
2" wide x 50' long
'91LX Vert- Stock Shortblock, Stock Cam, Cobra Intake, Edelbrock Performer 1.9's, 42#er's, PMAS 3", AOD, 3.27 gears, B&G 70mm Single, 3500lbs w/ me
Best 1/8- [email protected] with a 1.64 60'
Best 1/4- [email protected] with a 1.66 60'
Funniest 1/4- [email protected] LOL
Doug Hatton1 is offline
post #20 of 80 Old 04-07-2009, 12:41 PM
Erich's Avatar
Nice looking stuff.
Erich
Erich is offline
post #21 of 80 Old 04-07-2009, 12:57 PM
I have a couple brand new rolls of black 2" wrap if interested.
Ratedz...i made sure i DIDN'T have that hacked up look. I hate that, looks all buck tooth with the cooler sticking out,lol. Tucked it up nice!
post #22 of 80 Old 04-07-2009, 04:15 PM
jonyboy107's Avatar
Yes
THats an autozone air filter.... wth?
weird.
DAILY DRIVEN: 92 GT
post #23 of 80 Old 04-07-2009, 05:03 PM Thread Starter
Rich G's Avatar
yea the filter is bobo
Rich G is offline
post #24 of 80 Old 04-07-2009, 05:06 PM
NoSlo90- Do you have picutures of your front bumper after the trimming?
got9lbs is offline
post #25 of 80 Old 04-07-2009, 07:27 PM
No i don't, i recently bought a new computer and my antique of a digital camera apparently isn't compatible,lol.
post #26 of 80 Old 04-08-2009, 09:48 AM
I ended up not even being able to use mine. The turbo sat too close to the front and I couldn't get it in there without hacking up behind the headlight or something. I ended up buying that little stubby K&N and using it instead. (RU-2510) in case you need to do the same.
post #27 of 80 Old 04-08-2009, 10:40 AM
Wow, that sucks it doesn't come with IC brackets.. I would have expected it to do so.
ChaseGT is offline
post #28 of 80 Old 04-08-2009, 10:53 AM Thread Starter
Rich G's Avatar
Indeed, I was quite dissapointed with that, the more that I look at this kit the more I realize how cheap they are and how easy I could have built one myself and saved so much money.
Rich G is offline
post #29 of 80 Old 04-08-2009, 11:01 AM
ratedz's Avatar
Biggest reason i'm disappointed that the QuickTime kits fell out of favor. Bernard used far superior parts IMO
K&N filter, all Russel fittings, Tial BOV and WG, came with IC brackets, etc....
The B&G kit is still a great kit, just has some cheaper supporting items in it.
1986 Mustang GT
525hp/626tq
ratedz is offline
post #30 of 80 Old 04-08-2009, 11:18 AM
millhouse's Avatar
You'd be surprised how quickly all of those bits and pieces add up in a turbo kit. You have to remember that many of the items included in his are likely purchased in bulk, and therefore are considerably cheaper than what you or I can purchase for individually.
If I remember correctly, just my cold side silicone couplers ran me in the $150 range.
There is no doubt that you could likely have done it cheaper, but unless you fabricate a great deal of everything yourself and find awesome deals on new (and likely used) parts....you won't save "that" much.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #31 of 80 Old 04-08-2009, 11:23 AM
ratedz's Avatar
Completely agree - another thing, once the kit is on you'll soon forget who makes the fittings, air filter, etc.... none of it will matter once the car is running and you have a ####eating grin on your face
1986 Mustang GT
525hp/626tq
ratedz is offline
post #32 of 80 Old 04-08-2009, 11:27 AM Thread Starter
Rich G's Avatar
Yea from what I see the QT kits were much better than the BG kits, its a shame he let it fail.
Rich G is offline
post #33 of 80 Old 04-08-2009, 12:14 PM
87pony's Avatar
If it is the ceramic coat the reason it scratches so easily is because it is not fully cured. It has to be run to be fully cured.
87pony is offline
post #34 of 80 Old 04-08-2009, 08:08 PM
pennex1's Avatar
I feel your disappointment. I too was extremely dissappointed with my kit as i had to do some serious modification to make it work. Smashing the firewall, trimming the swaybar mount, completely redoing my cold side. It is a good thing that i learned or just took a chance and bought a TIG welder and modified my kit to fit my car.
My air filter didn't fit either. I started to trim my head light area and said forget this filter. My car was just painted. You can get a smaller K&N filter and use a air inlet kit for the track and the smaller K&N for the street.
http://www.turboneticsparts.com/?gcl...FQpxHgodCTur-A
Given some credit though, it is kinda tough to try and make things fit right when you have all these different aftermarket mounts, k-members, etc. That all gets factored in. My opinion of the B&G kit is that it is ok, but could be much better. Some people have had very good luck with their kit fitting. I didn't. Would i buy it again? probably not, maybe just the headers, but since i learned how to TIG, i would probably attemp to make my own header now. I paid $4500 for my custom kit and i had to modified it. All coating had to be redone. Here is my build link at the turbo forum. You can see all the modification i had to do for my kit to fit correctly.
http://www.theturboforums.com/smf/in...topic=108757.0
If anyone who has the time and money, learn to weld and make your own kit. The money you spent on their kit, you can use that money and buy a decent MIG and the header kit and build your own kit. my $.02
Dart 347, High Ports, FAST XFI, TH400, Precision 78GTS,E85, 836hp 714tq.
pennex1 is offline
post #35 of 80 Old 04-08-2009, 08:14 PM Thread Starter
Rich G's Avatar
I know the feeling, I dont think my kit is that bad but man im losing motivation fast. If I knew it was gonna be this much trouble I woulda just built my own kit
Rich G is offline
FS: Treadstone 62mm Fox turbo kit *NEW* ChaseGT Power Adders 23 04-12-2009 09:40 PM
Treadstone turbo kit 5.8LiterImportEater Power Adders 5 04-04-2009 12:13 AM
New bg turbo kit 87-93 foxbody nmnotch Power Adders 3 04-03-2009 08:10 PM
AFR Headed turbo motor and complete turbo kit jtsmg Windsor Engine Parts 5 04-02-2009 04:46 AM
WTT, Hellion turbo kit for your blower kit. BIG RCB Power Adders 2 03-24-2009 12:09 AM
