TURBO FUEL QUESTIONS - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 20 Old 04-03-2009, 12:57 AM Thread Starter
Trader Feedback: (25)
Hey Everyone, Heres almost the last line of my questions for this turbo build. Its comming down to start up time and these are the last leg of parts needed.
Im running a stock 91 302 block with approx. (33,***original miles)
Im running E-303, Edelbrock Performer Aluminum Heads, 1.72 rockers, Manley Chromeoly Pushrods, Edelbrock Performer Upper/Lower Intake, Edelbrock/BBK 75mm Throttle Body.
Rear End
-3:73 Ring and Pinion
-4-lug Moser 31 Spline Axles
-Auburn Posi
Trans
-Stock t-5
-Speck 2+ Clutch
-FMS Aluminum Driveshft
Power Adder: Cartechs SS Turbo Kit. 60mm Percision Turbo.
My goal is to have this car dynoed and tuned by Bob Kurgan at 10-12lbs. More on the 10lbs.
So far my fuel set up is the following.
Fuel
-Aeromotive Red Aluminum Fuel Rails
-Aeromotive AE13101 Adj. FPR
-Aeromotive Y-Block
-Stock Sumped Gas Tank
Im going to be running a -8 stainless steel main feed line and -6 stainless steel return line.
My QUESTIONS
1. What Inline pump should I purchase. It will be tuned at 10-12lbs of boost and this will be a street car and needs to be able to cruise around for hours?
2. What kind of fuel filter set up will be needed also?
3. What size injectors and Matching Blow thru maf will suit me the best?
Bob Kurgan said to run 60lb EV1s, SCT Chip, SCTBA2400 MAF.
Anyone have any helpful information.
Thanks Alot
PaT #06
94Stanggt5.0 is offline
post #2 of 20 Old 04-03-2009, 08:07 AM
if im going to tune it, i would recommend using the stuff that I suggested.. I have done that setup MANY times with great success and great drivability etc.. as far as the pump, i have walbro inlines and walbro intanks in stock.
PLEASE EMAIL --->
<--- DO NOT PM for prices or tuning!
815-669-RACE (7223) <--- Sales
Please visit our e-store --->
Chicagolands largest Vortech dealer since 2006!
We stock many parts! If you dont see it, just ask!
Before you buy ANY mustang part, give us a chance. We accept mastercard and visa.
Authorized SCT, AEM, Diablosport, Vortech, Paxton, BS3, FAST, UPR, PA Racing, Harland Sharp, Team Z, GMS, Trickflow, Kooks, and MANY MORE!
flyin_hawaiin is offline
post #3 of 20 Old 04-03-2009, 08:14 AM
SCstang88's Avatar
listen to bob lol
-88 GT H/C/I 306, T-trim, meth, C4, Glenn's fuel system. Runs..
SCstang88 is offline
post #4 of 20 Old 04-03-2009, 02:14 PM Thread Starter
Oh yea Im def listenin to him, the part that im trying to figure out is what model walbro Inline pumps I need, and how to set up the fuel lines/fuel filters/pumps/mounting.
PaT #06
post #5 of 20 Old 04-03-2009, 02:33 PM
ratedz's Avatar
Very similar combo here with a 67mm turbo - 306, TEA TW heads, ecam
I run a simple Walbro in tank pump, stock lines, rails with 48lb accel injectors. SCT chip and BA2800 maf.
I'd like to move to braided lines and an inline pump as I already have the sumped tank so i'll keep an eye on this thread for suggestions.
1986 Mustang GT
525hp/626tq
ratedz is offline
post #6 of 20 Old 04-03-2009, 07:46 PM
WHITEMACH's Avatar
Trader Feedback: (23)
if bob is tuning it then use his recommended stuff.
WHITEMACH is offline
post #7 of 20 Old 04-03-2009, 08:29 PM
i have the pumps in stock
PLEASE EMAIL --->
post #8 of 20 Old 04-03-2009, 08:44 PM
Blackfive0's Avatar
Trader Feedback: (62)
Bob has the pumps just give him a call and will send you what you need. He has always pointed me in the right direction.
Blackfive0 is online now
post #9 of 20 Old 04-03-2009, 08:53 PM
Trader Feedback: (43)
i have 60s, sct meter/chip from kurgan and the car runs pretty good on the base. Now if i can only get a freaking day off work to get it tuned...............
Precision 67mm turbo, this and that.
Thewhite88pony is offline
post #10 of 20 Old 04-07-2009, 09:28 PM Thread Starter
how much we talking for the walbro inline pumps Bob?
Im in need of 2 ?
How much for the pumps/60lbers/matching MAF
And i will purchase the SCT CHIP upon tune this year?
Thanks Alot
PaT #06
post #11 of 20 Old 04-07-2009, 09:56 PM
Im in need of 2 ?
Thanks Alot
PaT #06
email me.. i will set you up with a package price!!
thanks bob
PLEASE EMAIL --->
post #12 of 20 Old 04-07-2009, 10:24 PM
jturmanator's Avatar
I'd highly recommend ditching the 373's!
jturmanator is offline
post #13 of 20 Old 04-07-2009, 10:42 PM
ratedz's Avatar
I'm curious about the -8 and -6 lines that will be run - aren't these a bit too small?
I was told to run -10 and -8 for feed and return for my setup.
1986 Mustang GT
525hp/626tq
ratedz is offline
post #14 of 20 Old 04-07-2009, 11:35 PM
The 327s are love with a turbo.
DEF do not get 355s, 327s FTW
post #15 of 20 Old 04-08-2009, 01:16 AM
xr8240's Avatar
Good luck with T5..
I have -8 feed and -6 return
Using two Bosch motorsport 044 pumps.. over 600 rwhp..
No fuel supply issues..
Y block to each fuel rail feed from back to fuel reg in joined to both fuel rails at the front..Magnafuel fuel reg..Using Walbro 225 as intank pump to surge [sump] tank..
xr8240 is offline
post #16 of 20 Old 04-08-2009, 02:36 AM Thread Starter
Yea i believe the -8 main and -6 return will be fine for this setup. This car will be making around 400-500HP for awhile. Money shortages and paying for college tuition.
I have a stock sumped tank. Do u have to run an intank pump? The gentleman whom i purchased this tank from has a hose that connects both pickup ends. Is this how you run a sumpped tank. Im not to intelligent when it comes to all this fuel supply.
PaT #06
post #17 of 20 Old 04-08-2009, 07:14 AM
Whoever told you that was on crack or talking about something at an entirely different level of power than the original poster. Even with that said and I have heard the reasoning for running a -10 feed with a -8 return but I am still not sold on more than a -6 being needed on most setups. The -10 I will buy into although I personally rather run 2 -8s than one -10 but that is just me having in my head it is easier to route that way and I have done both so something must have made my head think that.
post #18 of 20 Old 04-08-2009, 08:44 AM
i run -8 feed and -6 return on my race car and it has gone 7.88 @ 176mph at 3300lbs... and i have plenty of fuel left..
PLEASE EMAIL --->
post #19 of 20 Old 04-08-2009, 12:48 PM
ratedz's Avatar
That's great to hear for me, I believe the smaller lines are a bit cheaper anyhow.
Dug out the article in which I read about the -10 fuel lines.
5.0 Mustang and Super Fords December 2007 article titled: Fuel System Secrets
Here's the 42-foot breakdown for a 350-400hp street/strip fuel system:
AN -6/Return: 21 feet
AN -8/Main Feed: 18 feet
AN -10/Tank-to-Pump: 3 feet
The -8 line can be used as primary fuel feed to support as much as 500 rwhp, but it's more common use is as a primary feed for 'Stangs that put out a maximum 350 to 450horses. The AN -10 braided is madatory for engines that produce 600 hp or better at the rear wheels. Fuel volume is much more critical for those applications.
1986 Mustang GT
525hp/626tq
ratedz is offline
post #20 of 20 Old 04-09-2009, 01:55 AM Thread Starter
thanks for the info guys.
Dealing with Bob on the setup.
PaT #06
FEW TURBO QUESTIONS? 94Stanggt5.0 Turbochargers 15 04-09-2009 01:58 AM
Turbo Questions???? mustangman57 Turbochargers 6 04-03-2009 10:37 PM
Fox EFI Fuel Pump CHEAP! ram360 Fuel System & Related 0 03-22-2009 03:07 PM
Fuel System questions 2dxtrm Superchargers 4 03-18-2009 02:43 PM
