FEW TURBO QUESTIONS? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 03-30-2009, 09:53 PM Thread Starter
Trader Feedback: (25)
Hey Guys, I have a few turbo questions. Im almost finished on the Cartech SS kit on my 91GT.
Few questions.
1. What kind of gasket should I run for the Downpipe and the Turbo Intake Gasket? Also wheres the cheapest to purchase?
2. Currently I have the stock Recirculating Bosch BOV and im looking to run an atmospheric. Where should the BOV be installed?
3. Im going to be running 60lbers, SCT Chip and a BA2400 i believe. Where should I run the MAF? Best location for this kit? I think its going to run between the TB and IC? GOOD LOCATION?
Ill post some pictures when i get home of my kit.
Thanks alot
PaT #06
94Stanggt5.0 is offline
post #2 of 16 Old 03-30-2009, 10:45 PM
fred50stang's Avatar
Few questions.
Thanks alot
PaT #06
1. I use fel-pro and put the high temp sealant (redish/orange stuff) on the gaskets.
2. My BOV is after turbo before a/a cooler
3. Maf, before throttle body with at least 4-6in of straight pipe leading to the maf.
fred50stang is offline
post #3 of 16 Old 03-30-2009, 11:07 PM
WHITEMACH's Avatar
Trader Feedback: (23)
i am with FRED like he said X-2
WHITEMACH is offline
post #4 of 16 Old 03-31-2009, 06:11 PM Thread Starter
What kind of gaskets should i run for the down pipe, and the intake portion on the turbo, that mounts to the header? Let me know
Thanks for all the information so far
post #5 of 16 Old 03-31-2009, 06:47 PM
Where my dp hits the back of the turbo, I just used copper rtv. Same for where the turbo mounts to the header. All of my v-bands use copper rtv too.
1994 Turbo GT
mustangless is offline
post #6 of 16 Old 04-01-2009, 12:50 AM Thread Starter
Alrighty sweet deal, So Copper RTV is better than gaskets???
Whats everyone running for header bolts? anything special ???
Thanks for all the help guys
post #7 of 16 Old 04-01-2009, 02:07 AM
92stanggt5.0's Avatar
Is yours a passenger side mount? And if so does it have a really thick manifold to head flange? Mine does.
1995 Cobra white/tan and a T64
92stanggt5.0 is offline
post #8 of 16 Old 04-01-2009, 12:51 PM
A Cartech SS kit on a 91 GT will have the turbo "header" on the drivers side but might very well have a thick flange still just seems to depend on when the kit was made. With that said I ran the same ARP header bolts with my Cartech kit that I did with the long tube headers I had prior to the kit. I do not recall anything special about those header bolts, I think they did have a 3/8 head but might be wrong on that, slept since then so not remembering too well.
post #9 of 16 Old 04-01-2009, 04:35 PM
Most say copper rtv is better than gaskets. Its too hard for me to work with, plus my header is not flat, so I use gaskets and copper rtv there. I also use stock headerbolts. I have stock headers too.
If I could find a re-usable gasket for the dp, I would get one for sure.
1994 Turbo GT
post #10 of 16 Old 04-03-2009, 12:37 AM Thread Starter
Well it looks like Copper RTV is winning so far.
Hey, Yes its a driversside turbo mount.
Heres some pictures of the kit.
Thats the kit.
Let me know
Thanks Again everyone
PaT #06
post #11 of 16 Old 04-03-2009, 06:31 PM
Angry_Man's Avatar
Looks like you are going to have a really fun car. As long as the surfaces are flat the copper RTV will seal just fine. I have a TTI street kit and had the hot side coated. After the coating the header was a little warped and did sit flush. Took it to a buddy that has a big table type belt sander and got it flat. Copper RTV and no leaks.
Angry_Man is offline
post #12 of 16 Old 04-03-2009, 07:42 PM
WHITEMACH's Avatar
looks good!
post #13 of 16 Old 04-07-2009, 09:29 PM Thread Starter
thanks for all the compliments. Yea shes commin along. Many long nights,money, and bitchin from the girlfriend lol hahaha
Yea I cant wait to drop it in.
PaT #06
post #14 of 16 Old 04-07-2009, 09:49 PM
Trader Feedback: (43)
The girlfriend thing will NEVER END dude lol
You got a lane when you're running
Precision 67mm turbo, this and that.
Thewhite88pony is offline
post #15 of 16 Old 04-08-2009, 01:27 AM
xr8240's Avatar
I use 1mm copper wire as gasket if RTV doesn't work..
I bend it 1/2 way around studs so they hold the wire in there, with some rtv.. The copper wire is soft annealed. Works fine...
The wire join is behind one of the bolts. I find smoothing out flanges with a little extra removed around studs/ bolt holes helps tension where gasket would tend to blow out..
xr8240 is offline
post #16 of 16 Old 04-09-2009, 01:58 AM Thread Starter
Hey, Thanks for the tips and tricks guys. Looks like im picking up some Copper RTV and having some arts and crafts time.
Anyone running a sumped tank?
Blower to Turbo 306 Fox SCstang88 Turbochargers 110 05-18-2009 03:13 AM
AFR Headed turbo motor and complete turbo kit jtsmg Windsor Engine Parts 5 04-02-2009 04:46 AM
Twin turbo questions?? earlsflyincobra Turbochargers 2 03-30-2009 04:11 PM
Turbo Magazine 700HP Twin Turbo 5.0L fstncln Windsor Engine Parts 0 03-25-2009 01:48 PM
Gt4276mm turbo kit for 351w determendford Power Adders 3 03-18-2009 08:38 PM
