Twin turbo questions?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 03-30-2009, 03:33 PM Thread Starter
When running twin turbos do you need to run two boost gages and two EGT gages??
earlsflyincobra is offline
post #2 of 3 Old 03-30-2009, 03:53 PM
BradleyRJ's Avatar
Trader Feedback: (25)
No on the two boost gauges. One single boost gauge referenced from a point as close to the T/B.
You can run two separate EGT gauges to keep tabs on temps. IMO not necessary but it would possibly help tell you if there is a oil restriction (or water if water cooled) if one turbo was getting hotter than the other.
They say what goes up must come down but I ain't reached my cruising altitude.
Take a look at what I did but can you imagine what I'm about to do.
BradleyRJ is offline
post #3 of 3 Old 03-30-2009, 04:11 PM
Thats not what EGT gauges are used for.
Exhaust Gas Temp is used to adjust mixture in some turbo applications.
We dont use EGT's for mixture. We use WideBand O2 sensors.
It can be nice to know if one bank is rich or lean, but not necessary.
One is plenty for average set-up
r.barn is offline
F/S Incon 800tt Twin Turbo Kit 2 GTBB28 turbos I8URrice Power Adders 6 03-30-2009 04:29 PM
Turbo Magazine 700HP Twin Turbo 5.0L fstncln Windsor Engine Parts 0 03-25-2009 01:48 PM
FS/FT 94' twin Turbo Project AtlongLast Mustangs For Sale/Wanted, 1994-1998 1 03-24-2009 10:09 AM
Brand New Twin 60mm Turbo Kit for 96-04 4v Richo Modular Engine Parts 2 03-22-2009 08:13 PM
Brand New HP Twin 60mm 4v Turbo Kit Richo Power Adders 24 03-21-2009 08:26 PM
