Wastegate question! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 03-29-2009, 04:09 PM Thread Starter
Blame Canada!!!!!! I FAP for CANADA!
fapperDan's Avatar
Trader Feedback: (44)
Exclamation Wastegate question!
Can I use the wastegate on a 99 ps turbo? What psi are they set for? a/r is 1.10
Banned!!!!!!!!!!!!!!!!
Canada loves me this I know, Cause the "Don" tells me so! Tumbleweeds we sell all day long, Ghost towns are coming so stay strong!
fapperDan is offline
post #2 of 6 Old 03-29-2009, 06:02 PM
wow,
you are going to need to give more information then that.
What is your engine, what boost level you want to max out at.
Wastegate size is determined by how much boost you do not want to make.
snowb07 is offline
post #3 of 6 Old 03-30-2009, 12:19 AM Thread Starter
fapperDan's Avatar
Originally Posted by snowb07 View Post
wow,
I wanted to know if i could use the waste gate on the turbo not an aftermarket one. Powerstroke turbo's have a wastegate on them already, re-read the post
post #4 of 6 Old 03-30-2009, 12:47 PM
good luck then.
snowb07 is offline
post #5 of 6 Old 03-31-2009, 10:51 PM
91GTman's Avatar
The PS turbo wastegate should push over 20 psi. My turbo came with a 32+ psi wastegate. I replaced it will the smallest psi wastegate I could find which was 6 psi. I will use a boost controller to up the boost from there. Check out the link below. it is not the exact internal wastegate that I got but it is close.
http://www.atpturbo.com/Merchant2/me...gory_Code=WGT1
91 GT Stock Block 306, 5sp, RPMs, F303, Spyder Intake, DIY GT4294 Turbo, Tweecer RT, PLX-300, BE, EA
60' = 1.51
1/4 = [email protected]
91GTman is offline
post #6 of 6 Old 03-31-2009, 11:19 PM Thread Starter
fapperDan's Avatar
Awsome man. You have done me a great favor. That is exactly what I need. You are a weath of info. Once again thanks!
94 GT convertible keyless entry question 84convertablegt 94/95 Tech 38 05-03-2010 10:44 AM
question about choosing cams badass03gt GT & SOHC 16 03-24-2009 05:16 PM
331 Piston question 94GreenMachine 5.0/5.8 Engine Tech 2 03-20-2009 08:45 PM
Rod order and balance question hickfied 5.0/5.8 Engine Tech 10 03-20-2009 12:49 PM
Engine swap question NPI to PI MVK13 GT & SOHC 3 03-13-2009 06:46 AM
