E-cam or F-cam - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 03-28-2009, 10:21 PM Thread Starter
E-cam or F-cam
hey all i am thinking about changing my cam from the current e-cam to a f-cam. My mods are a b and g turbo kit featuring a 70mm turbo with a .81 a/r put on a 306 bottom end with forged pistons and all arp fasteners. stock gt-40 heads with a ported lower cobra intake. 70 mm throttle body. currently i have a e cam with 1.6s and thinking about doing a f-cam to better benifit the turbo setup. Oh also my piston have plently of valve clearence and i have good springs up to .530 lift and cromemoly retainers. also i have not installed the turbo yet. I am also trying to see what rwhp i should put out with 10 pounds on a conservitive tune. thx
New Setup: 5.0 Coyote Swap, LTs, JLT, Tune. 435 rwhp 419 rwtq. 11.365 @ 121mph on NT05.
Old Setup: 306 forged bottom end, stock gt40 heads, 1.7s stock cobra intake, e- cam and bolt ons 275rwhp and 315 rwtq on a break in tune
sneaky94cobra is offline
post #2 of 13 Old 03-28-2009, 10:22 PM
2stangcoupes's Avatar
Trader Feedback: (43)
i'd throw a stocker in it if you're driving it alot on the street
2stangcoupes is offline
post #3 of 13 Old 03-28-2009, 11:39 PM
F cam is great with turbo
dentfix is offline
post #4 of 13 Old 03-29-2009, 09:44 AM
Rich G's Avatar
Trader Feedback: (35)
I have been doing a TON of research on this subject and unfortunately its not very clear.
However most of the turbo guys LOVE the F-Cam.
They will tell you however that the e-cam or a stock cam is capable of making more then enough power to break a stock block.
Personally I ended up going with a Trick Flow Stage 1
Rich G is offline
post #5 of 13 Old 03-29-2009, 10:03 AM
mbricher's Avatar
I run an e-cam with 1.6's in mine and it works great! If you are running a stock block and already have the e-cam I would just leave it. You can make more then enough power with it.
1990 Mustang GT
Dart IE 363, PT78 HPS, Built 4R70W, BS3, BBRC Fuel system, TeamZ, ect.....
Tuned by Bob Kurgan
mbricher is offline
post #6 of 13 Old 03-29-2009, 10:55 AM
I had an F Cam in my old Notch with a Novi and I loved it...It worked great...I went from a B cam to and F cam with the same blower and WOW what a difference...just my 2 cents bro..you wont be dissapointed with the F cam
procharged01GT is offline
post #7 of 13 Old 03-29-2009, 11:39 AM
ratedz's Avatar
Running an E cam here, seems to work great for my little combo.
1986 Mustang GT
525hp/626tq
ratedz is offline
post #8 of 13 Old 03-29-2009, 12:09 PM
staticstang's Avatar
I've got an X-cam on mine. I've never had it dyno'd but it consistently runs 127-129mph on 8-9psi.
staticstang is offline
post #9 of 13 Old 03-29-2009, 01:50 PM Thread Starter
wow thats pretty good I am thinking about running around 10 psi hopefully do mid to high 400 rwhp am low 500 rwtq and hopefully trap 122 to 125
post #10 of 13 Old 03-29-2009, 02:37 PM
WHITEMACH's Avatar
Trader Feedback: (23)
flip a quarter either one will work well
WHITEMACH is offline
post #11 of 13 Old 03-29-2009, 03:12 PM
klu408's Avatar
Trader Feedback: (18)
Just keep in mind (STOCK BLOCK) Ask me how I know!!
klu408 is offline
post #12 of 13 Old 03-29-2009, 03:13 PM
93Svt331's Avatar
Trader Feedback: (38)
f cam here..
if you have the e in it keep it inthere...
90 lx, 408w, T56, 88mm
93Svt331 is offline
post #13 of 13 Old 03-29-2009, 10:04 PM
97SVT's Avatar
E should work fine for you, especially since you already have it installed
1967 Mustang Coupe
1990 Mustang GT Turbod DD
1987 Mustang GT Turbod-9.75 @ 140mph gone but not forgotten
97SVT is offline
BIGGEST CAM? jonb347 5.0/5.8 Engine Tech 81 03-31-2009 09:39 AM
Comp HR custom blower cam 302/351 [email protected] Windsor Engine Parts 1 03-28-2009 06:41 PM
What Cam should i go with? The Novice 5.0/5.8 Engine Tech 29 03-26-2009 04:10 PM
Major problems with cam in my shortblock,, distRIBUTOR gear all chewed up I8URICE 5.0/5.8 Engine Tech 20 03-25-2009 07:35 PM
which cam do I run? OneSickBlackCoupe 5.0/5.8 Engine Tech 0 03-11-2009 11:54 AM
