Jet sizes - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 03-23-2009, 09:04 PM Thread Starter
Jet sizes
Whats up guys?Any suggestions on jet sizes for a blowthru carb setup?850 mighty demon,Super Vr,AFR 205s,408 w)comp solid roller,76 mm precision turbo,QT kit,11 lbs.
Also,how can I post some pics on here for everyone to check out?
Alan VanBuren is offline
post #2 of 12 Old 03-27-2009, 08:16 PM Thread Starter
Finally spoke to someone who has a little knowledge of blowthrough setups,let him know what powervalve and jets were in the carb(PV 6.5,PRI. 85,SEC.93)850 mighty demon.These are the standard jets that come in the carb.I was told to drop the jet sizes approximately 10 sizes.This is where this does'nt make sense to me;i have a 408 with AFR 205s,C4,QT turbo (76 mm)hoping to push about 12-15 psi.Does it make sense to go down in jet sizes when this type of setup loves fuel?It seems to me that maybe i should stick with the jets that i have or go up.
post #3 of 12 Old 03-27-2009, 08:34 PM
fred50stang's Avatar
Wish I could help you out buddy.
If you are doing a blow through...dont you have to have a 'blow through' specific carb?
fred50stang is offline
post #4 of 12 Old 03-27-2009, 08:55 PM Thread Starter
Some do,some don't.Alot of the holes that have to be filled on other carbs dont exist on the demons.(choke hole)Ive seen some use blowthrough and some not.This is supposed to be a RACE carb so ill try it and find out.The bitch should fly!
If i figure out how to post some photos i'll put them on here.LOL
post #5 of 12 Old 03-28-2009, 12:16 AM
WHITEMACH's Avatar
Trader Feedback: (23)
call procharger bet they can help ya!
WHITEMACH is offline
post #6 of 12 Old 04-08-2009, 10:18 PM Thread Starter
Dang it, i'm gonna go ahead and buy a 750 blow thru and sell my 850 dp demon.
post #7 of 12 Old 04-08-2009, 11:44 PM
Trader Feedback: (36)
Lotsa blow thru info on turbomustangs.com
scotng is offline
post #8 of 12 Old 04-09-2009, 07:55 AM
Trader Feedback: (18)
85/93 jet size in blow thru carb is considered a safe tune, it'll probably be pig rich though..................go to turbomustangs.com in the carb section....there are a lot of new ways to have the carb run smaller jets via vent tube extensions and boost reference powervalves.
kingstang is offline
post #9 of 12 Old 04-09-2009, 10:22 AM Thread Starter
Hey thanks guys,I've been visiting that site as well,which is why will probably go with the demon or csu.Anyone want to buy a 850 mighty demon?Never run.
post #10 of 12 Old 04-13-2009, 06:14 PM
If the carb has nytrophil floats, there is not much left to be done. Get rid of the PV protector, block the HSABs and jetting up 5 sizes front and back
should get you close. Do you have a wideband?
'67 coupe, blow-thru 351w S475, C4/C5, 8.8 6.38 at 110, 9.99 at 135
brianj5600 is offline
post #11 of 12 Old 04-13-2009, 09:53 PM Thread Starter
Thanks Brian,pickin up WB & 750BT on friday!
post #12 of 12 Old 04-14-2009, 07:09 PM
look up brent davis on turbomustangs , he is a blowthru guru.
dentfix is offline
Edelbrock 1406 Calibration Jet Rod Kit Dustang83 Fuel System & Related 0 03-18-2009 08:45 PM
original 428 cobra jet exhaust manifolds_ matching pair for sale lastrebel Exhaust Parts 1 03-18-2009 07:18 PM
Jet powerchip #78803 pushrod88 Electronics and Entertainment 0 03-14-2009 03:59 PM
