Lightning mass air - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 03-13-2009, 12:47 AM Thread Starter
Lightning mass air
I did some research but i cant find a definite answer,
I am running a single turbo kit and am expecting approx. 550-600hp and i was wondering if i can run my Lightning mass air as a blow thru for this much power. thanks
ProjectNotch is offline
post #2 of 4 Old 03-13-2009, 01:00 AM
If you run it with a MAF extender, such as the Diablo MAFia, yes. The 80mm MAF will give you more range than the 90mm MAF in the same housing.
SonicFox is offline
post #3 of 4 Old 03-13-2009, 11:47 AM Thread Starter
can the c&l 73 mass air work as a blow thru or should i just bite the bullet and buy the pmas blow thru mass air?
post #4 of 4 Old 03-13-2009, 12:33 PM
I believe pretty much any MAF can be run as a blow-through. The difference might be the limiting of the dynamic range. But, a MAF extender would solve that issue.
SonicFox is offline
