MSD digital 6 plus guys??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 18 Old 03-12-2009, 08:55 PM Thread Starter
red89coupe's Avatar
Trader Feedback: (31)
is your green loop wire cut or not?
red89coupe is offline
post #2 of 18 Old 03-12-2009, 09:06 PM
Trader Feedback: (43)
I'm not sure.
I'm looking for the same answer myself smokey.
Precision 67mm turbo, this and that.
Thewhite88pony is offline
post #3 of 18 Old 03-13-2009, 08:15 PM
jturmanator's Avatar
Mine is not, just noticed it. The instructions say to cut it in the front of the book. Must have overlooked this, step.
I read that the green loop provides a timing compensation for different style trigger pick ups.
Now I wonder if this is the reason my car didnt pick up much power after the 1st intial timing adjustment during my tune????
jturmanator is offline
post #4 of 18 Old 03-13-2009, 08:47 PM
STOCK 5.0's Avatar
You are only supposed to cut the green loop if you are not using a EFI Ford distributor. That is the answer i got directly from MSD tech line when i put my Digital 6 in my car 5 years ago.
So if your car is EFI with either the stock TFI dizzy or the MSD replacement TFI dizzy leave the loop connected.
STOCK 5.0 is offline
post #5 of 18 Old 03-13-2009, 10:36 PM
How's the 2 step work with a push button?
post #6 of 18 Old 03-14-2009, 12:27 AM
Mine works awesome. I did a small video of it. Here is a link:
http://www.youtube.com/watch?v=vNSxT...e=channel_page
1993 Silver Coupe
8.25:1, F-303 cam, TFS Track Heats, BBK SSI Intake, 42lb inj, Tremec 3550, 3,73's, Pypes Exhaust, 03 Cobra brakes.
Hellion "Heat" kit - 66mm T-Trim w/GTK housing. 8lbs for now. (435hp/460tq)
HellionFox is offline
post #7 of 18 Old 03-14-2009, 08:54 AM Thread Starter
red89coupe's Avatar
I ran mine off a realy / the clutch / a momentarty switch.
basicly you hold the clutch in and the momentary switch at the same time. let go of the push button momentary and the clutch holds the 2 step on.. once clutch is out it turns off until you hit the BOTH clutch and the button again..
I have the wiring diagram somewhere if you like. it make it much nicer.
is yours a digital 6?? if so is the green loop cut??
I swear mine was CUT for almost 2 years.. The box was out for a while and the wire was cut but when I went to put it back in the car I guess I was trying to send smoke signals to Chicago..lol
I miss the 2 step allready but on a good note with JUST a MSD coil, I can still run 12psi without spark blowout lol
the MSD book says cut the wire, call MSD they say leave it, call summit racing tech and get even more confused lol...
post #8 of 18 Old 03-14-2009, 07:18 PM
I cant seem to find 12v from my clutch switch?
post #9 of 18 Old 03-15-2009, 12:01 PM
http://yfrog.com/0m919350eecwiringdiagramg
Looks like i need to tap into the red/grey wire in bottom right corner of diagram.
post #10 of 18 Old 03-15-2009, 09:12 PM
Gt
Gt's Avatar
Trader Feedback: (23)
Then they need to update the instructions. I ran it for years cut, per the instructions. Had no issues with it either.
http://www.msdignition.com/uploadedF...structions.pdf
Page 5
Magnetic Pickup Compensation
Note: If your application uses the MSD's White wire for the trigger input, the magnetic compensation circuit is not used.
The Green wire loop of the MSD provides a timing compensation for different style trigger pickups. Having the ability to program for the style pickup being used provides a more accurate timing signal. This compensation is used primarily with crank trigger or locked out timing applications.
The Digital MSD is programmed at the factory for use with an MSD Crank Trigger or GM magnetic pickup. If you are using an MSD Billet Distributor or the magnetic pickup of a Ford or Chrysler distributor the Green Loop should be cut and sealed (Figure 3).
Note: It is recommended to check your total timing to ensure the setting for your application.
Tony Whetstone
'88 Gt Vert 348 S491 [email protected] 1.22 60' 275 DRs
'02 Gt VT Cam'd! [email protected] Sold
'05 6.0 Excursion
Gt is offline
post #11 of 18 Old 03-15-2009, 09:43 PM Thread Starter
red89coupe's Avatar
Page 5
THANK YOU VERY MUCH !!!!
I had mine hooked up like that for a long time with NO issues. I got used from a guy running a turbo mustang and the wire was cut. I read the instructions and it said cut, so I left it cut.. ran great until I tried to catch it on fire lol
post #12 of 18 Old 03-15-2009, 10:24 PM
The question of the day is, how much if any does this affect timing??? May need to go to MSD forums to find out.
post #13 of 18 Old 03-15-2009, 10:50 PM
put a timing light on it and check
PLEASE EMAIL --->
<--- DO NOT PM for prices or tuning!
815-669-RACE (7223) <--- Sales
Please visit our e-store --->
Chicagolands largest Vortech dealer since 2006!
We stock many parts! If you dont see it, just ask!
Before you buy ANY mustang part, give us a chance. We accept mastercard and visa.
Authorized SCT, AEM, Diablosport, Vortech, Paxton, BS3, FAST, UPR, PA Racing, Harland Sharp, Team Z, GMS, Trickflow, Kooks, and MANY MORE!
flyin_hawaiin is offline
post #14 of 18 Old 03-16-2009, 07:13 PM
STOCK 5.0's Avatar
They dont need to update the instructions. A TFI dizzy is NOT a magnetic pickup.
post #15 of 18 Old 03-16-2009, 07:25 PM
Gt
Gt's Avatar
Read all the instructions, not just what I posted above.
Another part on Page 4:
This wire loops out of the strain relief. It is used to compensate for different magnetic pickups. The MSD is set up to be used with GM distributor and MSD crank triggers. If you are installing the ignition with an MSD Distributor or Ford Distributor, this Loop should be cut and sealed
That plainly says just "Ford Distributor". Doesn't say anything about TFI vs magnetic.
Or the reference to "Figure 3" diagram in the post I did above this one, where the diagram says "Factory Ford".
Looks like they need to clean up the instructions.
Gt is offline
post #16 of 18 Old 03-17-2009, 03:08 PM
D O A's Avatar
My wire is NOT cut. Where do the red and blue wires go!!!!!
88 Notch. QT PT 6776 turbo kit, Edelbrock RPM, Cometic, Crane 1.6, f303, LW bell, 6 pt., 3.73, strange adj. 6AL, MB Jr. upper/lower control arms, T5-Z, SRP pistons, main support, windage tray, FAST XFI, Strange spool & 33 spline axles, c-clip, Spec III, Flaming River man. rack, Team-Z anti-roll
D O A is offline
post #17 of 18 Old 03-17-2009, 03:21 PM
Gt
Gt's Avatar
Blue = This wire activates the Two Step Rev Control. When 12 volts is applied to this wire, the low rpm limit is activated. When 12 volts is removed, the rev limit returns to the high limit.
Pink= This wire activates the retard stage when it is applied to 12 volts. When 12 volts is removed the retard is deactivated.
Gt is offline
post #18 of 18 Old 03-17-2009, 03:44 PM
D O A's Avatar
Thanks!!
D O A is offline
