What intake for a T76 R-Block 331? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 03-11-2009, 11:10 PM Thread Starter
Montman's Avatar
I'm shooting for 600-700rwhp. I'm going to use TEA TW 205's, a cammotion custom turbo cam, but I'm not sure on the intake. I'm looking at the TFS-R, The Victor 5.0 or maybe a super victor EFI with an elbow. What do you guys think?
Montman is offline
post #2 of 11 Old 03-11-2009, 11:28 PM
Super Vic EFI with elbow - FTW
r.barn is offline
post #3 of 11 Old 03-12-2009, 12:54 AM Thread Starter
Montman's Avatar
I forgot to mention that I want it to fit under a stock hood too. Will a super vic and an elbow fit?
Montman is offline
post #4 of 11 Old 03-12-2009, 12:56 AM
yes, most elbows are designed to put the TB in "stock location"
and there are some low profile and angled elbows available.
r.barn is offline
post #5 of 11 Old 03-12-2009, 11:47 PM
biminiLX's Avatar
R-Box with TEA lower port matched, HPM drop mounts
-J
'91 LX hatch
Bimini Blue
427"/88mm at 16 psi
biminiLX is offline
post #6 of 11 Old 03-13-2009, 04:48 PM
chris123's Avatar
Trader Feedback: (43)
Im running a victor 5.0 on mine. See signature for dyno #'s
358 cid Dart block (8.2 deck) foxlake ported Victor Jr's
Victor 5.0 Anderson b4 cam BBK long tubes TKO 600
Anderson Motorsports YSI 8/2.95 10 rib setup
755RWHP @ 6750 RPM'S on pump gas & meth
chris123 is offline
post #7 of 11 Old 03-13-2009, 10:06 PM
Trader Feedback: (41)
I would run a spyder intake on that setup. It is very close to my setup and also my friends setup.
I have a 352 (302 based) 9:1, TEA TW 205's, custom small solid roller and a PTK turbo kit with a GTS 76mm and made almost 800RWHP through an AOD at 15psi. Drivibility is awesome and it should fit under a stock hood.
I would stay away from the Victor 5.0 and Trick Flow R intake. Also the super Victor has to high of an rpm range on a 331 from most setups. You will be happier with the Vic Jr IMO.
stangjumper is offline
post #8 of 11 Old 03-13-2009, 10:41 PM
WHITEMACH's Avatar
Trader Feedback: (23)
x-2 victor 5.0
2012 GT AUTO
bbr tune ,bbr x-pipe,jlt cold air
[email protected]
WHITEMACH is offline
post #9 of 11 Old 03-14-2009, 12:31 AM Thread Starter
Montman's Avatar
I appreciate all the responses. Those are some awesome hp numbers.
stangjumper, why no victor 5.0 or tfs-r?
Montman is offline
post #10 of 11 Old 03-14-2009, 11:18 AM
super vic.
Swampdonkey is offline
post #11 of 11 Old 03-14-2009, 11:30 AM
I wouldn't run a "long" runner intake on that setup. You don't need it with a turbo.
Also less weight with a carb style intake.
If you ever decided to run meth injection the long runner intakes aren't designed to run liquid through them. The carb style intake will really shine here.
