sigle or twin - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 03-11-2009, 08:17 AM Thread Starter
haitham_c6's Avatar
sigle or twin
I have 351w with blowercharg 177 holley....i remove the blower ...
i want to put turbo..but i dont know if sigle or twin is the best for daile use with out any prblem....and with good power.....
haitham_c6 is offline
post #2 of 15 Old 03-11-2009, 11:50 AM
same same
just depends on what you like and what you're after.
Twins will spool up a little better, but cost a little more to do.
I went with twins on my set-up just because I found it
was going to be easier to run 2 small downpipes vs 1 large downpipe
and easier to fit 2 small turbos than 1 large one.
Both work equally well, almost more of a cosmetic preference more than
anything.
My homemade 351W with twin T3/T4 Garrett turbochargers
and flipped BBK headers.
r.barn is offline
post #3 of 15 Old 03-11-2009, 06:30 PM Thread Starter
haitham_c6's Avatar
ok...what you think about sigle 76mm.......
post #4 of 15 Old 03-11-2009, 08:46 PM
jman511115's Avatar
Hey R. Barn what trim and AR are your turbos? I've got a very similar setup to yours, except mine is a 302 and the wastegates are internal.
64,999,987 firearms owners killed no one yesterday.
NRA member and you should be too! It's about more than just the guns. Join here.
https://membership.nrahq.org/forms/signup.asp?CampaignID=FrdmAssoc
jman511115 is offline
post #5 of 15 Old 03-11-2009, 09:15 PM
Trader Feedback: (41)
IMO I would run a single. Duals are more money, more weight, and more to plumb.
What power are you looking to make?
stangjumper is offline
post #6 of 15 Old 03-11-2009, 10:08 PM
single 76 would be good turbo for 351W up to say mid-low 600's at the wheels.
r.barn is offline
post #7 of 15 Old 03-12-2009, 07:38 PM Thread Starter
haitham_c6's Avatar
thats good...
my engine 418ci with 225cc . 2.05 valve heads and custom cam from erson 112.3 lop...
how much i get HP you think ???
post #8 of 15 Old 03-12-2009, 11:10 PM
I made almost 800RWHP with a 76 on a 352 and that was "only" at 15psi. There was quite a bit left if I didn't run out of injector.
post #9 of 15 Old 03-13-2009, 07:22 PM Thread Starter
haitham_c6's Avatar
yes..
verey good
post #10 of 15 Old 03-14-2009, 11:25 AM
thats good...
I'd run twin 60-1's or single 88 on engine that big.
Make 1000rwhp if you want it to.
I'd get a different cam also. 112 LSA is not ideal for a turbo cam.
Thats an N/A cam spec.
Turbo cams usually run more like a 115-117 LSA to help prevent reversion
from pre-turbo back pressure. ....... just a thought.
r.barn is offline
post #11 of 15 Old 03-14-2009, 02:29 PM Thread Starter
haitham_c6's Avatar
you mean i must chang the cam ???
post #12 of 15 Old 03-14-2009, 03:43 PM
What are the specs on the cam that you have now?
post #13 of 15 Old 03-14-2009, 04:05 PM
No, you dont HAVE to, but you might think about it.
+1 post specs. Lets see what you have.
Sure your current cam will work, it just may not be the "best" unless it
was spec'd for a turbo motor.
r.barn is offline
post #14 of 15 Old 03-15-2009, 05:46 AM Thread Starter
haitham_c6's Avatar
the cam 112.3 LSA....
post #15 of 15 Old 03-15-2009, 10:03 AM
There is MUCH more to a cam than the LSA.
What is the duration at .050" lift????
