What do I do with this PCV hole now? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 03-09-2009, 02:38 AM Thread Starter
D O A's Avatar
Question What do I do with this PCV hole now?
Ran a line from each valve cover to a oil catch can. So what do I do with this PCV hole? I'm pretty sure these two things were in there at one point and time but how do I plug it up?
Thanks,
Ben
88 Notch. QT PT 6776 turbo kit, Edelbrock RPM, Cometic, Crane 1.6, f303, LW bell, 6 pt., 3.73, strange adj. 6AL, MB Jr. upper/lower control arms, T5-Z, SRP pistons, main support, windage tray, FAST XFI, Strange spool & 33 spline axles, c-clip, Spec III, Flaming River man. rack, Team-Z anti-roll
D O A is offline
post #2 of 12 Old 03-09-2009, 07:24 AM
You can buy plugs for them, unfortunately the names of companies that sell them are eluding me right now. I always just ran a PVC in the hole, even if it was non functioning(not needed).
post #3 of 12 Old 03-09-2009, 04:58 PM
fred50stang's Avatar
I still run my PCV. I tested it under positive pressure, nothing gets by it. I also run a -10 line from each valve cover to a catch can.
fred50stang is offline
post #4 of 12 Old 03-09-2009, 05:35 PM Thread Starter
D O A's Avatar
Yeah I ran -12 to my catch can, little over kill I think but it sounded good at the time. I was thinking of puting a new screen in, pcv valve and cap it off.
If you remember what the name of the company is let me know. Thanks all.
D O A is offline
post #5 of 12 Old 03-09-2009, 07:02 PM
jonyboy107's Avatar
Trader Feedback: (15)
Can you run just a pcv and no breathers... I don't want the smell...
DAILY DRIVEN: 92 GT
306,9,5:1,AFR 185s,RPMII,xe264hr,ProMagnum rockers,turbonetics 66S,bg kit,METH,Flowmaster catback,Accufab race 75mm,pro tube,60lb injectors,255lph walbro BAP,ac delete,no smog,full MSD ignition,mark fan,3G alt,TKO600,spec stage 3,alum flywheel,3.55s
jonyboy107 is offline
post #6 of 12 Old 03-09-2009, 08:24 PM
BAERSysteMAX's Avatar
Trader Feedback: (33)
take out the screen, and cut the bottom off the PCV valve and take out the check valve. now put a piece of 3/8" rubber hose on it and snake it down the fire wall and forget about it. i ran it that way for years, no issues
90 lx 5 speed... 10.5 @ 136 stock bottom end and cam... ford junk !
86 gt ttop
90 coupe [email protected] turbo pump gas street car
BAERSysteMAX is offline
post #7 of 12 Old 03-09-2009, 08:45 PM
Thunder5.0's Avatar
I kept the pcv valve but attached an air filter on top of it. So I have three filters all together. So far so good.
Thunder5.0 is offline
post #8 of 12 Old 03-09-2009, 11:29 PM
jturmanator's Avatar
Any pics of the filter? I just unhooked the hose running to the valve and left it all by its lownesome self.
jturmanator is offline
post #9 of 12 Old 03-16-2009, 09:22 PM
Rich G's Avatar
Trader Feedback: (35)
subscribing
Rich G is offline
post #10 of 12 Old 03-17-2009, 02:59 PM Thread Starter
D O A's Avatar
Ended up buying a new PCV, installed it and capped it off. Should work.
D O A is offline
post #11 of 12 Old 03-23-2009, 09:16 AM
Rich G's Avatar
Rich G is offline
post #12 of 12 Old 03-23-2009, 11:59 AM
measure the hole then go buy a freeze plug to fit; did it to mine, but I do not remember the plug size needed.
Pope is offline
