Wastegate Size help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 03-08-2009, 02:00 PM Thread Starter
Josh93's Avatar
Wastegate Size help
Is there anyway to tell what size wastegate I have? There's no writing or anything on there. I need to know what size WG I have so I can get a softer spring. I can post some pics if you guys think you could tell.
1988 SSP Coupe-04 Cobra Swap
Josh93 is offline
post #2 of 8 Old 03-08-2009, 05:23 PM
Trader Feedback: (41)
You have to know what brand/model WG you have. Each one uses a different spring. To see what size it is just measure the opening.
stangjumper is offline
post #3 of 8 Old 03-08-2009, 09:30 PM
red89coupe's Avatar
Trader Feedback: (31)
yep!! a 38mm is gonna be around 1 1/2 and a 44mm is around 1 3/4.
red89coupe is offline
post #4 of 8 Old 03-08-2009, 09:36 PM
my8950's Avatar
Measuring it would be a good start...
If you are changing the spring though, you should remove the gate and disassemble it, measure the piston inside, it should have a "channel" or something inside that the spring will sit in so its not sliding around inside.
my8950 is offline
post #5 of 8 Old 03-09-2009, 11:43 PM Thread Starter
Josh93's Avatar
I'll look into it. Im takin it by a friends house and lettin him check it out sometime. I'll just stay out of boost till I get the time.
Here's some pics anyway
Josh93 is offline
post #6 of 8 Old 03-10-2009, 06:10 AM
1995gtCPE's Avatar
Trader Feedback: (34)
Looks like a 38mm tial knockoff.
1995gtCPE is offline
post #7 of 8 Old 03-10-2009, 09:02 AM
my8950's Avatar
Its looks hooked up correctly too. Are you driving the car without that installed?
What spring is in there now? And what is your goal?
my8950 is offline
post #8 of 8 Old 03-10-2009, 11:34 AM Thread Starter
Josh93's Avatar
No, I took off the header to have some welding done and I snapped a pic of it. The guy I got it from said it was a 15lb spring. My goals are just to have a quick street car with around 500hp.
Josh93 is offline
