Incon twin turbo kit... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 26 Old 03-03-2009, 10:14 PM Thread Starter
I am looking at getting a turbo kit, a buddy has a incon turbo kit for a fairly decnt price so i was wondering how good is the kit?? What kind of power can i make out of it with 2 t3/t4 turbos, its going on a stock 302 with H/C/I
I8URrice is offline
post #2 of 26 Old 03-04-2009, 05:50 AM
Michael Yount's Avatar
Enough to split the stock block.
Michael Yount - Charlotte, NC - 82 Volvo 242 - 6.2L; '17 Mazda3; '16 CrossTrek
Michael Yount is online now
post #3 of 26 Old 03-04-2009, 06:22 AM Thread Starter
i guess thats all that matters than
I8URrice is offline
post #4 of 26 Old 03-04-2009, 08:56 AM
twofast's Avatar
the incon kit was rated to 800hp.
68 coupe
351W PT-88 E-98
700hp/643tq [email protected]
radials/street driven
twofast is offline
post #5 of 26 Old 03-04-2009, 09:36 AM Thread Starter
would you guys recomend the incon kit or a single 76mm holset turbo??
I8URrice is offline
post #6 of 26 Old 03-04-2009, 07:11 PM
ncontt's Avatar
depends on how much you like to change plugs....I'll go ahead and tell you it's a PITA with the incon kit....I got it to where I could do it in about 1 1/2 hours #6 is downright brutal to get to and #3 isn't much fun either, however a nice selection of sparkplug sockets is nice (specially the one that has a "wrenching" area at the top of it, so you can turn it with a wrench. All that being said.....the incon kit is AWESOME....almost INSTANT spool and it sounds AMAZING!!!!!!!!!!!!! This was on my 331 and I wish I wouldn't have sold it now but that's not here or there.
In the end it really boils down to what kind of price you can get each for....that's my $.02
~~Project OMG RUKIDN ME?~~
built aod, 03 Mach I rims, Pony Down Stage 3 Kit,Tokico 5 way illumina's, Systemax upper/lower,indiglo gauges, Pa 130 amp alt., various phantom gauges, 331 B50 Block, Forged internals,TFS stage 2 heads/cam and 4 doors of FUN in a 79 Ford Fairmont
ncontt is offline
post #7 of 26 Old 03-04-2009, 08:20 PM
X2 on the block split.
MOOVS is offline
post #8 of 26 Old 03-05-2009, 06:13 AM
any way I can get one of these kits now? its the only CA legal kit
mchector is offline
post #9 of 26 Old 03-05-2009, 12:47 PM
twofast's Avatar
keep an eye out on the classifieds.
68 coupe
351W PT-88 E-98
twofast is offline
post #10 of 26 Old 03-05-2009, 12:48 PM
twofast's Avatar
regarding the sparkplugs:
i only had problems with #6. #6 took as long to change as all of the other 7 together.
68 coupe
351W PT-88 E-98
twofast is offline
post #11 of 26 Old 03-09-2009, 12:26 PM
Steed93's Avatar
Yes the sparkplugs are a PITA. Whenever you have to remove the turbo manifolds for anything, you have to pull the whole engine because it's way to hard to remove them with the engine installed. Otherwise, the kit is awesome and stealthy.
1993 LX hatch
11.21 @ 124
480 whp, 520 wtq (10 psi)
Steed93 is offline
post #12 of 26 Old 03-10-2009, 01:07 AM Thread Starter
well i just put on the kit today. what a PITA, unfortuantly the plugs are fouled out, i have to get this thing adjusted..
these turbos are TINY i dont understand how they can do the job, they are the T28s
I will keep u guys updated with some pics soon.
I8URrice is offline
post #13 of 26 Old 03-10-2009, 08:23 AM
twofast's Avatar
are you sure it's an incon kit and not an old ddmi kit?
68 coupe
351W PT-88 E-98
twofast is offline
post #14 of 26 Old 03-10-2009, 10:34 AM Thread Starter
how can i tell the difference?? What is a ddmi kit is it any good?
I8URrice is offline
post #15 of 26 Old 03-10-2009, 12:10 PM
twofast's Avatar
the ddmi kit was a predecessor to the incon kit. it had smaller turbos and was rated to 600hp, iirc.
as far as telling the difference between the two, you may have better luck asking that at turbomustangs.com.
68 coupe
351W PT-88 E-98
twofast is offline
post #16 of 26 Old 03-10-2009, 02:28 PM
Did you have to notch the frame rail? If not then you either have one of the very few 600tti Incon kits or you have a DDMI. They both use the same manifolds more or less, maybe even similar intercoolers(I forget ) but some of the plumbing is different between the two.
post #17 of 26 Old 03-10-2009, 11:20 PM Thread Starter
i had to notch the rail, and the piping is silicone and not metal
I8URrice is offline
post #18 of 26 Old 03-12-2009, 07:41 PM
94cobra2615's Avatar
You can run mid to high nines with an 800 incon kit with the right setup. The turbos used in the kit aren't your average turbos. They are ball bearing and spool VERY quick. Garrett GT series.....model GT2871R. Try to price one of these turbos to buy.....last I looked a new one was around $1600 for just 1
94cobra2615 is offline
post #19 of 26 Old 03-12-2009, 10:19 PM Thread Starter
how do u like your kit?? what kind of power are you making??
I just did the spark plugs, took me a little over 2 hours..#3 is a bitch!
I8URrice is offline
post #20 of 26 Old 03-12-2009, 10:34 PM
I thought they used some special housing which is what made a turbo for an Incon kit even more expensive than one would expect. But do people really need to replace the entire turbos on those kits?
post #21 of 26 Old 03-12-2009, 11:27 PM
PUR PONY's Avatar
I love my Incon kit! my 306 makes 563rwhp/610rwtq at the moment. Plugs are a pain in the ass but if you take your time and stay calm, its not that bad. I have changed them several times already.
-'89 Coupe - Incon Twin Turbo - Sheetmetal Elbow on a EFI Victor-Trick Flow Heads-Viper T56-RXT-Baer Brakes-iforged Wheels-Griggs,MM,KB-DFI-
PUR PONY is offline
post #22 of 26 Old 03-13-2009, 12:01 PM
carbd86gt's Avatar
I loved my Incon kits. A lot of the local guys had never heard of them before and I always just told them that the car had an Incon cold air kit and exhaust, lol. Worked very well at night during the street races since the manifolds were black, god I miss that kit. Plugs got me riled up a few times, but I didnt have to change them that much, I really enjoyed driving my Incon car.
Muscular Stang Racing - Mustangs racing to cure Muscular Distrophy
Visit
to see what we are about.
carbd86gt is offline
post #23 of 26 Old 03-13-2009, 06:24 PM
Yes, they had special housings. I don't even think I priced an actual INCON turbo with the special housings. I was just letting the O.P. know the turbos arent your average T3/T4 turbo.
post #24 of 26 Old 03-13-2009, 06:49 PM
RwbMstng's Avatar
Too bad Incon went out of business.. I'm surprised no one has really re-produced the headers? Or has any company since tried?
RwbMstng is offline
post #25 of 26 Old 03-25-2009, 09:40 PM
MCLFLN's Avatar
Location: Taylorville, Illinois, United States of America
unfortunately, I doubt you will ever see a kit like the Incon kit built for a pushrod 302 motor again. Were they perfect, no...but if you wanted an OEM quality turbo set up - they were and are your only option
MCLFLN is offline
post #26 of 26 Old 03-26-2009, 09:18 AM
They used manifolds and were a "copy" of the DDMI manifolds to begin with. There would be no point in copying the manifolds unless someone went through all the trouble of copying a lot of other things since the turbos themselves were somewhat unique to the application as well. 2-3 years ago someone told me that a person was working on re-introducing the kit to the market and "I would be surprised to find out who was working on that". I am guessing that attempt fell through since so much time has passed and I have yet to be "surprised".
Closed Thread
