What gasket? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 03-02-2009, 04:20 PM Thread Starter
What gasket?
Finished B&G installation and could not wait to go down the road. Found out that one quarter throttle is too much for untuned turbo.
High_Voltage is offline
post #2 of 13 Old 03-02-2009, 05:19 PM
ssj50driver's Avatar
MLS or cometic gasket is what I would recommend.
ssj50driver is offline
post #3 of 13 Old 03-02-2009, 05:22 PM Thread Starter
Going back with fel pro 9333. The gasket that was eaten was a 1011-1 and it worked good for a while.
post #4 of 13 Old 03-02-2009, 05:32 PM
red89coupe's Avatar
Trader Feedback: (31)
good choice.. I run either a 8548pt2 or the 9333pt1. Only difference is one has a alum fire ring and the other is tin.. cant reber for sure which is which but I THINK the 8548 has the tin fire ring.
I have had GREAT luck with both.
red89coupe is offline
post #5 of 13 Old 03-03-2009, 02:02 AM
I had the same problem. HAHAHA
to fix it I went with mr.gasket MLS gaskets with copper spray on both sides. Just make sure you get the right one for your setup. Their phone support line was great, would recomend again.Haven't had a problem since.
88lx Conv. 200K mile stock longblock. Trickflow intake, 42lb inj, Pmas protube,TKO500, 3:27, pypes muffs, Pa Racing tubluar K-member, DIY single turbo setup. Summit aluminum rad, Crane Hi-fire ign, subfames, 17" sc saleen's, Saleen ground effects, SCT tune by Dynosport. 380HP 435ftbs.
71swing is offline
post #6 of 13 Old 03-03-2009, 07:29 AM Thread Starter
I was reassembling last night and realized that I had the vacuum line on top of the wastegate, instead of the bottom. Yes I get the fail.
post #7 of 13 Old 03-08-2009, 12:07 AM Thread Starter
HOOOOOOOOLLLLLLLLYYYYYY SSSSSS****************!!!!!!!!!!!!!! Got car back running tonight and....... my god..... turbo ftmfw. It is amazing! Wideband shows 10.2 at wot and timing is at 10* base.
post #8 of 13 Old 03-08-2009, 12:16 PM
Bobo's Avatar
So did that cause you to overboost?
Scotty we need more power!!!
Bobo is offline
post #9 of 13 Old 03-08-2009, 12:57 PM
ratedz's Avatar
I run the Mr. Gasket MLS - which is made for them by Cometic - no spray, adhesive, etc... just installed them and torqued the heads.
1986 Mustang GT
525hp/626tq
ratedz is offline
post #10 of 13 Old 03-08-2009, 11:29 PM Thread Starter
Got back from track and ran 7.03 @ 99.37. Millhouse was right about two-step. It pulls a wheel nicely. Now on to 3.27 gears.
post #11 of 13 Old 03-09-2009, 12:30 AM
ratedz's Avatar
I gain .2 in my 60' using my 2 step
1.75's to 1.55's
1986 Mustang GT
525hp/626tq
ratedz is offline
post #12 of 13 Old 03-23-2009, 04:06 AM
I had the same problem, switched to 9333. Kinda scared now to floor it, I don't want to change HG's again.
Whats your total timing and boost on what gas?
L&StangNC is offline
post #13 of 13 Old 03-23-2009, 05:40 AM
Rich G's Avatar
Trader Feedback: (35)
Untuned you still need to be careful, with 10deg initial your at 26deg total which is a bit much
Rich G is offline
