brakes on a turbo car? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 03-01-2009, 10:32 PM Thread Starter
Anyone know for sure if i need to convert to manual brakes on my car since it will be turbo now? Since i will be making boost instead of vacuum, i wasnt sure?
thanks for any input,
Ty
notch88 is offline
post #2 of 8 Old 03-01-2009, 10:54 PM
you only make boost at wot, and some part-throotle, brakes work fine with turbo
Turbomustang
Mesarina is offline
post #3 of 8 Old 03-02-2009, 01:00 AM
+1, your brakes will be fine. although with the added power you will now be able to go faster so it wouldnt hurt you to upgrade your brakes
TWIN TURBO!! Because bottles are for babies and superchargers blow
megasquirt, 331, twin 66s, ported 205cc head, efi spyder intake, 160# injectors, e85
luckythirteen13 is offline
post #4 of 8 Old 03-02-2009, 07:22 AM
millhouse's Avatar
+2
Your brake booster has a check valve to ensure it does not get pressurized. If you have ever brake-boosted on a auto'd turbo vehicle....you'll see everything still works fine.
I will agree though, if you are running the stock breaks I would ABSOLUTELY upgraded them if you haven’t already. The stock brakes are barely adequate for the stock platform....let alone an extra 150+ rwhp. If you don't do it now....you'll end up spending more from replacing your rotors every time they warp from a high speed slowdown.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #5 of 8 Old 03-02-2009, 02:45 PM Thread Starter
i still have the stock rear drums but my fronts are upgraded to 13 in rotors along with bigger calipers...i think they are off a cobra? What about doing a burnout...wont the boost take away my vacuum and keep my brakes from working and holding the car?
notch88 is offline
post #6 of 8 Old 03-02-2009, 02:50 PM
millhouse's Avatar
The check valve is there to keep from losing vacuum while the brakes are depressed. This is regardless of whether you’re in boost or not….to to answer your question, no it won’t.
post #7 of 8 Old 03-02-2009, 08:38 PM Thread Starter
awesome! thanks guys...didnt really wanna spend any more money.
Ty
notch88 is offline
post #8 of 8 Old 03-03-2009, 12:06 AM
if you lost vacuum at the booster, the pedal would just be harder...
Turbomustang
Mesarina is offline
