B&G on my sn 95 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 02-27-2009, 01:23 PM Thread Starter
B&G on my sn 95
i currently bought a new motor for my sn 95. so i want to run a master power T76, where can i get one , and is it worth the upgrade?? its going on a 331dart block, strocked to a 427ci, fully build motor.
chico95gt is offline
post #2 of 9 Old 02-27-2009, 01:27 PM
strokercharged95GT's Avatar
I am also looking at doing this upgrade and Im not sure what you mean stroking a 331 8.2 decked block to a 427. You need different blocks for that and your turbo kit will require modification to work on the tall decked black.
2013 Mercedes GLK-350
strokercharged95GT is offline
post #3 of 9 Old 02-27-2009, 01:29 PM Thread Starter
yeah we need some custom tube bending for the kit to fit. but i mean how much is a t76? and where can i get one from?
post #4 of 9 Old 02-27-2009, 04:09 PM
blacksaleen95's Avatar
You're going to be seriously choking that motor with a t76 on it, esp if it's a p-trim wheel. I'm running the big bore dart, 4.125, stroked to 363 with a pt88. IMO you should go with a larger t4 based turbo with that motor... Any particular reason you want to go with the t76?
blacksaleen95 is offline
post #5 of 9 Old 02-27-2009, 04:37 PM
MATLOCK's Avatar
def. a T4 based turbo
TURBO'D NCR 302 G.R.E.A.D. TUNED
MATLOCK is offline
post #6 of 9 Old 02-27-2009, 04:55 PM
http://www.turbochargers.com/store/p...roducts_id/464
r.barn is offline
post #7 of 9 Old 02-27-2009, 08:11 PM
BAERSysteMAX's Avatar
Trader Feedback: (33)
hahaha look who it is
i do not know if you are confused with a 331 or 427 or whatever, and people here sometimes talk in circles, but if you have a big budget for that kind of motor, follow through with the turbo... i wouldnt look anything smaller then an 88mm. what is the rest of the combination ?
90 lx 5 speed... 10.5 @ 136 stock bottom end and cam... ford junk !
86 gt ttop
90 coupe [email protected] turbo pump gas street car
BAERSysteMAX is offline
post #8 of 9 Old 02-27-2009, 08:57 PM
Maybe he meant 351W Dart block stroked to 427ci.
In that case I would go with twin 60-1 or 62-1's
Twin Turbonetic 62-1's with .81 a/r would scream and come on line nicely.
r.barn is offline
post #9 of 9 Old 02-27-2009, 11:54 PM
Good luck on the SN95, not too many of us out there. I too am a little confused though. Are you going to punch a 8.2 block out to 427ci? I had Brian at AD Performance build me a Big Bore Dart 347ci for my project. BG is supplying the kit and T76. So if you end up with a BG kit just have Brain upgrade to the bigger turbo.
What are going to use the car for primarily, street car or track car?
kbscobravert is offline
