Oil line's question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 02-23-2009, 05:21 PM Thread Starter
92stanggt5.0's Avatar
Oil line's question
So here I am trying to get all the parts together for my kit and I realize that I don't have any oil lines for the kit. I have looked around for kits and the thing is that most of the ones that I have found have been on eBay.
SO, from the expertise that is on this site I am looking for some advice as to what to use. I have looked at the Vortech instructions and like the way they do it but it still leaves me with out a full kit to get it done.
The one eBay kit I found that I think is all that I would need is here...http://cgi.ebay.com/ebaymotors/_Car-...ayphotohosting
I am using a T64 with a Cartech SS kit on a 95 Cobra.
Thanks!
1995 Cobra white/tan and a T64
92stanggt5.0 is offline
post #2 of 5 Old 02-23-2009, 07:17 PM
NoSloCoupes's Avatar
Trader Feedback: (53)
www.racepartssolutions.com
*edit...look in turbo accessories.
NoSloCoupes is offline
post #3 of 5 Old 02-23-2009, 08:35 PM
BAERSysteMAX's Avatar
Trader Feedback: (33)
you will want a -4 feed and a -10 minimum return, -12 if space permits. use the feed from where you get the signal for your oil pressure and the return should be in the pan. i put mine where vortech recommends. i also had the pan off the engine and welded a -12 fitting to it.
you t64 should have a threaded oil inlet, 1/8" npt. you will need a drain flange and corresponding fittings and lines. id got with www.racepartssolutions.com i have bought from him before with no issue. he is a VERY helpful guy.
90 lx 5 speed... 10.5 @ 136 stock bottom end and cam... ford junk !
86 gt ttop
90 coupe [email protected] turbo pump gas street car
BAERSysteMAX is offline
post #4 of 5 Old 02-23-2009, 09:20 PM Thread Starter
I think that I will give that guy a call and just tell him what I need. I'm sure he will be able to help get the right stuff and not a bunch of worthless stuff.
post #5 of 5 Old 02-23-2009, 09:35 PM
even better idea !
86 gt ttop
