nonintercooled 10.5:1 with meth - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 02-20-2009, 12:56 PM Thread Starter
jonyboy107's Avatar
Trader Feedback: (15)
Can I get away without an intercooler? I am only looking to run about 6lbs, definitely no more than 8 since its only a stock block.
Setup is in my sig.
DAILY DRIVEN: 92 GT
306,9,5:1,AFR 185s,RPMII,xe264hr,ProMagnum rockers,turbonetics 66S,bg kit,METH,Flowmaster catback,Accufab race 75mm,pro tube,60lb injectors,255lph walbro BAP,ac delete,no smog,full MSD ignition,mark fan,3G alt,TKO600,spec stage 3,alum flywheel,3.55s
jonyboy107 is offline
post #2 of 3 Old 02-20-2009, 02:02 PM
Setup is in my sig.
I really would hate to rely on meth injection solely for detonation protection, i've seen one system fail and destroy the engine in a 1 yr old 30,000 dollar subaru sti. If you were going alky blow through it'd be a different story. Personally I'd either build another engine with a good block at a more desirable compression ratio. Or put an intercooled low boost setup on the car. Thats just my opinion, but even at low boost with that much compression and a decent set of heads your going to be in block splitting territory anyhow. By taking the i/c out of the equation when the air temps are up its really counter acting the benefits of the meth and would likely lead to issues. On a low compression setup it wouldnt be that big of an issue.
Swampdonkey is offline
post #3 of 3 Old 02-20-2009, 02:08 PM
kintaro's Avatar
Do it and then show us pics of your shortblock
kintaro is offline
