Thumper heads - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 02-13-2009, 10:58 PM Thread Starter
Thumper heads
Has anyone see or run e7 thumper heads with an f cam on a turbo car? Is it worth it or should I just wait and get a set or trick flow tw heads? Goal is for a 400-450 5 speed street car with a single 70mm.
got9lbs is offline
post #2 of 12 Old 02-14-2009, 10:18 AM
The problem with E7 heads is their thin deck and chances of lifting. No amount of work done to an E7 is going to fix that issue.
post #3 of 12 Old 02-14-2009, 11:42 AM
That and they are iron.
Aluminum heads dissipate heat much faster and help reduce hot
spots in the combustion chamber and detonation.
HIGHLY recommend aluminum heads with any boosted motor. Is mo-betta
r.barn is offline
post #4 of 12 Old 02-14-2009, 11:47 AM
While that is true, I have ran iron heads with great success on my boosted cars and seen my friends do it as well. I would not go out and buy a new iron head these days but I would not hesitate one second to buy a used set that were nicely done up. I would do that because people have in their heads iron heads have very little value so they resale for cheaper than they should. For example my old Dart Sr heads which got several cars in the 10s and a couple in the 9s, all boosted cars, sold for WELL under $1k, actually did not sell for much more than what had been recently put in them for a valve job, guides and seals.
post #5 of 12 Old 02-14-2009, 11:52 AM Thread Starter
hmm so i should start looking for some twisted wedge heads then.
got9lbs is offline
post #6 of 12 Old 02-14-2009, 08:29 PM
xr8240's Avatar
If you want to yes..
Also better valve gear.. Springs etc..
Good value for the $$
xr8240 is offline
post #7 of 12 Old 02-15-2009, 02:30 PM
red89coupe's Avatar
Trader Feedback: (31)
IF your only going for 400-450 hp it can be done with stock heads. however I would never suggest stock heads over TWs lol
red89coupe is offline
post #8 of 12 Old 02-16-2009, 10:54 PM
Trader Feedback: (18)
hey man, call livernois, ask for Andy, they have a really good deal on livernois CNC heads
Tony K is offline
post #9 of 12 Old 02-16-2009, 11:26 PM Thread Starter
are the livernois heads the rhs heads that they work over?
got9lbs is offline
post #10 of 12 Old 02-16-2009, 11:38 PM
jturmanator's Avatar
I got gt40 with a explorer intake. See sig below
jturmanator is offline
post #11 of 12 Old 02-18-2009, 12:53 PM
Yes, and the price is right. i was thinking about them and the victor Jrs after i sell my AFR's
Tony K is offline
post #12 of 12 Old 03-01-2009, 08:45 PM
P.F.M's Avatar
Whats up Karl? Got that bad boy ready to rock yet?? I want to see some pics. Put them up on MM. I'm hardly ever on over here.
Later
Paul
92 notch Black on black with Boost
P.F.M is offline
