Tapping for the oil feed - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 02-13-2009, 04:59 PM Thread Starter
Djstorm100's Avatar
I recently broke in half the 3 inch pipe in half that went in to the oil passage in to the block.
the problem is I can only find 2-1/2 inch and 4 inch brass pipe thats threaded on both ends. Will 2-1/2 be long enought so the tee does not interfere with the block/oil filter? I know the 4 inch will but I'm worried about the threads breaking off in the block. Reason for that is because of the weight of the oil pressure senor, how long the brass pipe is, and all the weight resting on just those threads.
Djstorm100 is offline
post #2 of 3 Old 02-13-2009, 08:48 PM
fred50stang's Avatar
I have seen guys run the longer one you mentioned with no issues.
Or try fleabay for a factory one. lol.
fred50stang is offline
post #3 of 3 Old 02-14-2009, 09:22 AM
XJHEAD's Avatar
http://www.grainger.com/Grainger/wwg...exId=1&typeOf=
Fastest Ethanol Powered Street Car in the World
SN-95 7.64 @ 187 315 Radials E-98
TT 427 TH-400 3400 lbs.
Baseline Supsension, Ed Curtis
XJHEAD is offline
