a couple fuel system questions - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 02-12-2009, 06:14 PM Thread Starter
I am getting ready to install an a1000 pump ran with a pickup tube, stock tank on a stock block turbo car. Do i need to run a relay switch with this pump and if so how big (30 or 40 amp?) Also, how big should the wires i run to operate the pump be...someone was telling me to run a ten gauge wire? And one more thing...should i prime this pump before i first turn the pump on or will it prime ok by itself?
thanks for any advice...
Ty
notch88 is offline
post #2 of 3 Old 02-21-2009, 11:22 PM
my8950's Avatar
Where are you installing the pump? Intank, or external? If external, where? The farther away from the battery, the larger wire you will need. Or, as I did, use 2 relays, one that will trigger the other down stream so that the pump is close to the supply relay. Although my battery is in the hatch, so I am not all that far away from the pump.
It needs a relay for sure, 40Amp at the least, and it will be fine to prime it when installed and you turn the key, just cycle it a few times to make sure the pressure is up, and holds....
my8950 is offline
post #3 of 3 Old 02-22-2009, 08:44 AM
XJHEAD's Avatar
I ran 10 ga. to a relay in the spare tire well and tapped the stock fuel pump wire to feed the relay.
Fastest Ethanol Powered Street Car in the World
SN-95 7.64 @ 187 315 Radials E-98
TT 427 TH-400 3400 lbs.
Baseline Supsension, Ed Curtis
XJHEAD is offline
