what kind of ignition for turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 30 Old 04-29-2008, 12:23 PM Thread Starter
347 with 70turbo, manual, just wandering what msd box to purchase to get a good time, the car has a 6a box, i was told i have to have a 2 step setup in order to have a good 60 footer, looking for some advice
STANGRIDER2 is offline
post #2 of 30 Old 04-29-2008, 01:19 PM
jturmanator's Avatar
MSD is suppose to be coming out with a new box with built in 2step in May. I'm not sure which route i'm going either, I wonder if there will be any bugs to work out. good thread.
jturmanator is offline
post #3 of 30 Old 04-29-2008, 01:44 PM
the Digital 6 + comes with a built in 2 step and timing retard... i've heard retarding the timing builds more boost quicker with a two step
gtconv91 is offline
post #4 of 30 Old 05-19-2008, 06:14 PM
I think im going with the Digital 6. Any of you turbo guys have any issues with this box?
post #5 of 30 Old 05-19-2008, 09:36 PM
red89coupe's Avatar
Trader Feedback: (31)
Not one issue in over a year. I LOVE it !!!
red89coupe is offline
post #6 of 30 Old 05-19-2008, 10:12 PM
Thunder5.0's Avatar
Digital 6 here too
Thunder5.0 is offline
post #7 of 30 Old 05-19-2008, 11:16 PM
KID CHICAGO's Avatar
Ive been looking for an answer to this question, looks like a digital 6 it is... Thanks guys
KID CHICAGO is offline
post #8 of 30 Old 05-20-2008, 12:04 AM
1foxbody32's Avatar
Trader Feedback: (26)
I have a digital 6 too it sounds sick on the 2 step its a very nice box.
SIRACING.NET
1foxbody32 is offline
post #9 of 30 Old 05-20-2008, 12:52 AM
You can find them on here used for around 150...
gtconv91 is offline
post #10 of 30 Old 05-20-2008, 01:16 AM
1foxbody32's Avatar
wow thats a crack head price let me know if you find one that cheap my dad wants one for his car too.
SIRACING.NET
post #11 of 30 Old 05-20-2008, 08:04 AM
qikazz's Avatar
I reached the limits of the Digital 6 box in my car. It came to a point where the car was misfiring at higher boost pressures. It just didn't produce enough energy to fire the cylinder. I switched over to a GM "coil on plug" setup. This is certainly not the easy fix. The thread is here where you can see how we mounted the coils down on the K-member - https://forums.corral.net/forums/show...=992432&page=4
If you keep pushing for more and more HP, you will have to at least step up to the MSD Digital 7 box, but these aren't nearly as streetable according to MSD. While some drive them on the street, MSD doesn't recommend it at all because they produce so much energy that they burn up when constantly street driven.
qikazz
'91 mod motor, turbocharged notchback, mid-8s... (SOLD)
'91 331ci GT, twin 76mm turbos, hopefully mid-7s...
'03 Evo, 2.0L, 68mm turbo, AWD street terror, mid-9s
qikazz is offline
post #12 of 30 Old 05-20-2008, 06:21 PM
What are the limits of the Digital 6?
post #13 of 30 Old 05-20-2008, 07:20 PM
1foxbody32's Avatar
x2
SIRACING.NET
post #14 of 30 Old 05-21-2008, 12:23 AM
Trader Feedback: (101)
spoke to MSD today on the Dig 6. They said 1000hp is about the limit.
papis408 is offline
post #15 of 30 Old 05-21-2008, 12:50 AM
red89coupe's Avatar
1000hp N/A or 1000 HP boosted??
I would THINK boost pressure plays a BIG factor in it. Either way it will outlast my stock block so Im all good lol lol
I LOVE mine. the 2step/timing retard is GREAT. I FINALLY got to use it at the track tonight. at 3500rpm I build basicly full boost (only 8 psi for me).
who says a 5 speed turbo car cant 60 foot. lol got a 1.63 60 on slicks FIRST time out but had to lift.. Slicks dont quite feel like DRs above like 60mph lol lol lol Gonna take me a bit to get them down, here I thought the launch was gooa be the hard part
post #16 of 30 Old 05-21-2008, 09:23 AM
xr8240's Avatar
I have wasted spark, ECU has 6 ignition ignition drivers...
What options do I have?? .. Dis-4 worth it ??.. 330 Dart block, 7.8 compression... At 15 Lb I'm blowing spark out with .020 plug gap...
What options do I have ??
xr8240 is offline
post #17 of 30 Old 05-21-2008, 11:51 AM
qikazz's Avatar
To be more precise, the issue is Cylinder Pressure. Obviously, this is greatly affected by boost pressure, but this is not the only factor when it comes to spark blow-out. Chamber design affects this as well.
My car is making approximately 950-1000fwhp right now, and we definately reached the limit of the Digital 6 box. You could see the misfires through the tuning software while the car was on the dyno. Now that we've switched it over to the GM stuff, this problem is solved completely.
qikazz
qikazz is offline
post #18 of 30 Old 05-21-2008, 11:53 AM
I'm closer to 100 HP than 1000HP, atleast for now.
post #19 of 30 Old 05-21-2008, 11:56 AM
qikazz's Avatar
Good for you because once you get infected with the bug that number just starts to rise uncontrollably
qikazz is offline
post #20 of 30 Old 05-21-2008, 05:39 PM
Warning: If you go to turbomustangs.com be prepared for at least three, condescending, know-it-alls (per thread) to come into your threads telling you to use the search button first...Have fun with that
This is so TRUE!
post #21 of 30 Old 05-21-2008, 08:13 PM
xr8240's Avatar
This is so TRUE!
I searched and that's what I came up with !!!
Know it all's ??? If they don't know the answere is "search"....
xr8240 is offline
post #22 of 30 Old 05-26-2008, 09:17 PM
I'd recomend the Digital 7 box think part number 7531. it'll do everything you want for a turbo car.
eleanordream is offline
post #23 of 30 Old 05-26-2008, 10:52 PM
Sorry for the late reply... but get ahold of this guy he should still have it..
drag5ltr
gtconv91 is offline
post #24 of 30 Old 05-27-2008, 09:52 AM
qikazz's Avatar
So true...
qikazz is offline
post #25 of 30 Old 05-27-2008, 02:27 PM
I am going to use my 7al-2 box and I just got the 8977 timing computer. It does everything that the Digital 7+ (boost referenced) can do, but with the reliability of the 7al-2 box. I could have even used the 6al box with this. Beware, it is pricy though...right at $500.
MNtony is offline
post #26 of 30 Old 05-27-2008, 06:29 PM
I'm sticking with the Digital 6, got to order one soon.
post #27 of 30 Old 05-28-2008, 02:09 AM
xr8240's Avatar
I already have wasted spark, but only 6 ignition drivers in stand alone ECU so I guess I have to go with a FOUR channel ignition box ??
Such as MSD Dis-4 or some sort of ignition like M&W http://www.mwignitions.com/ ...I am runing out of spark.. Plug gap is down to .020 and I feed I could get better fuel economy with better, stronger spark..
I have heard bad things about AEM ignition blowing up....
xr8240 is offline
post #28 of 30 Old 05-28-2008, 08:45 AM
vbstng's Avatar
you all talk about the 2 step built in, what about for automatic guys? same thing Digital 6 just as good?
91 MUSTANG GT
99 EXPLORER DAILY DRIVER
vbstng is offline
post #29 of 30 Old 05-28-2008, 08:34 PM
Yeah you put your 2step so your not going through the converter... or right before the stall... a lil more consistancy..
gtconv91 is offline
post #30 of 30 Old 05-28-2008, 08:56 PM
http://store.summitracing.com/partde...5&autoview=sku
this box i think is better than the msd a lil more options..
02 F250 PSD superduty - The Mule no mods yet.
90 Hatch - Will never be done. best e.t. to date 10.30 @ 133 ;
86 Hatch - Made two track outings and was parted out best e.t. to date was 9.X @ 14X
igotaneed4speed is offline
