Gt40 or Trickflow intake? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 18 Old 04-03-2008, 03:48 PM Thread Starter
jixxer's Avatar
Gt40 or trickflow intake with a quicktime turbo setup, which one do you guys think I should run? If anybody has a pic of a quicktime kit with gt40 would you post some pics.
jixxer is offline
post #2 of 18 Old 04-03-2008, 09:48 PM
liftedford17's Avatar
I wouldnt run a GT40. They are designed to make low end and stop making power around 5400 rpm. The trick flow would be better for a turbo especially. I would run a track heat since they make a ton of power to 6000rpm and still make some of the best low end power I have seen. I have a black one with less than 500 miles if you are interested.
liftedford17 is offline
post #3 of 18 Old 04-03-2008, 09:50 PM
Depends on what heads you are running.
blackstang95gt is offline
post #4 of 18 Old 04-03-2008, 10:15 PM Thread Starter
jixxer's Avatar
stock heads
jixxer is offline
post #5 of 18 Old 04-03-2008, 10:48 PM
rob
rob's Avatar
Trader Feedback: (23)
i run a gt40 intake with box stock gt40x heads with decent results and pulls like an animal to 6k where i shift.
rob is offline
post #6 of 18 Old 04-04-2008, 12:45 AM
Originally Posted by jixxer View Post
stock heads
GT-40 is all that is needed.
The stock mustang heads flow very poorly, all that an intake with too big of a cross section will do is limit your potential torque output.
This is not as big of an issue on turbo cars as n/a cars, but it still makes a difference.
If you plan on stepping up to larger heads in the not to distant future going with a larger intake now (any of the TF series) could be a real cost saver though.
post #7 of 18 Old 04-04-2008, 01:16 PM Thread Starter
jixxer's Avatar
I like the looks of the gt40 much better, the difference between the 2 should not be to noticable with a stock motor and a quicktime turbo kit?
jixxer is offline
post #8 of 18 Old 04-04-2008, 05:47 PM
mbricher's Avatar
I agree. If you are staying with stock heads the GT-40 will work great. But if you at all plan on getting aftermarket heads just go with the trickflow now. I run a track heat intake and love it.
1990 Mustang GT
Dart IE 363, PT78 HPS, Built 4R70W, BS3, BBRC Fuel system, TeamZ, ect.....
Tuned by Bob Kurgan
mbricher is offline
post #9 of 18 Old 04-05-2008, 02:13 AM
Don't take what I posted the wrong way. The GT40 is a very good intake even with larger heads. I switched from the TF Street Heat to a race ported GT40 lower and bone stock explorer upper on a Twisted Wedge Heads and TF Stage 1 cam engine and the car felt a lot stronger through the whole RPM band.
post #10 of 18 Old 04-05-2008, 08:12 AM
mbricher's Avatar
Not at all man. They are all good intakes. I was just saying with aftermarket heads I think the TFS will flow better than the GT-40.
1990 Mustang GT
Tuned by Bob Kurgan
mbricher is offline
post #11 of 18 Old 05-01-2008, 06:51 PM
Mustangspeedx89's Avatar
i would use an edelbrock victor intake with those large runners would do some boost good
Mustangspeedx89 is offline
post #12 of 18 Old 05-01-2008, 07:36 PM
Blackfive0's Avatar
Trader Feedback: (62)
It really is not going to matter what intake you run. You are over looking the fact that you have boost. No matter what both will make good power.
If you do plan on changing heads later on I would look into a rpm 2 or a system max.
Blackfive0 is offline
post #13 of 18 Old 05-02-2008, 12:11 AM
get a systemax... to a point no it dont matter what intake you get... just the fact you will be able to crack the block with the stock one... but you will need less boost to hit the number....
gtconv91 is offline
post #14 of 18 Old 05-02-2008, 06:49 AM
slo5.0.'s Avatar
^^ exactly..
If you need an intake.. i'd just get a cheap explorer gt40.. the boost will do all the work for you.
slo5.0. is offline
post #15 of 18 Old 05-08-2008, 07:48 PM
vbstng's Avatar
if your trying to stay cheap, anything is better than stock
91 MUSTANG GT
99 EXPLORER DAILY DRIVER
vbstng is offline
post #16 of 18 Old 05-09-2008, 05:33 AM
xr8240's Avatar
A bigger plenum helps with forced induction, depends on port alignment. Assuming you would have that sorted the TFS ...
xr8240 is offline
post #17 of 18 Old 05-09-2008, 04:25 PM
vbstng's Avatar
so you have trickflow heads then trickfloe intake should help more?
91 MUSTANG GT
vbstng is offline
post #18 of 18 Old 05-12-2008, 09:58 AM
That is what I was thinking and why I say just get whichever one you like the look of and can afford.
