Plugwire Hell on DIY twin turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 21 Old 03-24-2008, 12:48 PM Thread Starter
Erich's Avatar
For some reason, I just seem to have bad luck on my wires. First it was burning them. Recently I settled on these taylor spiropro wires that are cut to fit. I have had them on for maybe 3/4 of a year. I have not driven the car more than a few thousand miles.
Failed emissions with a 1200 ppm HC reading so I checked my wires.
Sure enough if you put a timing light on them you see missing flashes (not even). Also if you rev up and let the rpm drop, big blank spots. I put in some other wires temporarily and they do not do this. The taylors appear to be in good condition.
Could this be my crimping job coming loose?
Is the overall high temps in the engine bay ruining even fancy wires?
Temperature wise-since my headers fip up and they are the hotter than the downpipes, I was thinking of doing a new routing under the header and above the down pipe.
GRRR
I hate buying wires again and again!
Erich
Erich is offline
post #2 of 21 Old 03-24-2008, 03:42 PM
Formerly LocoGT
Insignificant's Avatar
Trader Feedback: (33)
The Taylors on my Camaro did the same bs. They are junk.
2018 Charger Hellcat
1999 Corvette
2004 Acura TL
Insignificant is offline
post #3 of 21 Old 03-24-2008, 03:52 PM Thread Starter
Erich's Avatar
When I asked the guy who tuned the car if the taylors were good, he said they are big.....
That sucks but at least its been seen before. What to get msd?
Erich
Erich is offline
post #4 of 21 Old 03-24-2008, 04:23 PM
millhouse's Avatar
I had issues with my MSD wires cracking after less than a years worth of turbo heat....to the point which when you pulled them the shielding slid off in your fingers.
I've been running moroso ultra 40's for the past year or two (cut to fit) and have nothing but praise for them. I will say that I myself had a shotty crimp job on a few wires...which I didn't find until I ohm'd the wires out.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #5 of 21 Old 03-24-2008, 04:40 PM
ARCANGL's Avatar
Trader Feedback: (76)
not to highjack, but threads like this make me glad i dont have wires
ARCANGL is offline
post #6 of 21 Old 03-24-2008, 04:49 PM Thread Starter
Erich's Avatar
Did you use a real plugwire crimping tool? or a wire striper type like me?
Erich
Erich is offline
post #7 of 21 Old 03-24-2008, 04:55 PM
millhouse's Avatar
Erich
Just a standard wire stripper (which has the built in crimping tool that doesn't work worth a damn).
post #8 of 21 Old 03-24-2008, 05:03 PM Thread Starter
Erich's Avatar
If I do it again (which I will have to) maybe I should buy the real thing. It was a crap shoot on the crimping for me.
Erich
Erich is offline
post #9 of 21 Old 03-24-2008, 10:02 PM
bikewiz's Avatar
Trader Feedback: (18)
I have the Taylor 409s on my car with DEI 1,200* boot covers and had good look last summer. I was running way high EGTs due to un-metered air leaks. So hot that I cooked a VS Racing turbo blanket, but the wires held up.
I was a genius and forgot to hook up the #4 wire before I put the car in storage and left the boot laying on the trans, arced the #### out of the wire.
Now I'm stepping up to the Taylor 409 10.4mm wires.
Matt
bikewiz is offline
post #10 of 21 Old 03-25-2008, 12:16 AM
Formerly LocoGT
Some FMS wires would be fine. Grab some heat sleeves from Summit & put them on.
post #11 of 21 Old 03-25-2008, 01:14 AM
bikewiz's Avatar
FMS=crap
Try ohming them out. They ohm out around 2-5k ohms per wire. My taylors are 40-60 ohms per wire.
Matt
bikewiz is offline
post #12 of 21 Old 03-25-2008, 01:24 AM
try using some of that reflective foil shielding or tape
under the protector boots also.
Thats should help reflect some of the infra-red heat coming thru
the protector boots and cooking the wires.
Remember "infra-red" heat is not just a radiant energy but an
electromagnetic wave that can be reflected by a foil surface just like
any other radio wave.
Think of those new "ceramic" space heaters at Home Depot.
They use a flame to super heat a ceramic plate that then generates
lots of infra-red heat.
r.barn is offline
post #13 of 21 Old 03-25-2008, 07:11 AM Thread Starter
Erich's Avatar
Yeah, I will try some real boot protectors and maybe that tape as well.
It is true that the motorsport wires show a high resistance. Not sure if that is necessarily bad. It may be in the relm of plug wires, that difference is not significant. Not sure. My summit brand wires tested very LOW resistance as did the taylors.
Can wires be heat damaged without appearing physically harmed?
Erich
Erich is offline
post #14 of 21 Old 03-26-2008, 06:46 AM Thread Starter
Erich's Avatar
Got up early and watched the wires in the dark. Plenty of arcing. That is after getting rid of the worst offenders.
Also my MSD "blaster" (arcer?) coil seems to be arcing internally or something. You look straight at it and can see two verticle lines of arc on the front of it. Nice.
Erich
Erich is offline
post #15 of 21 Old 03-26-2008, 11:03 AM
Erich
MSD coils suck donkey balls.
It took me weeks and trip to the mechanics with their special ignition
diagnostic machine to figure coil was crap. Made spark, but was back feeding
all kinds of screwed up voltages into the system. MSD dizzy was a hunk of junk too.
Go Motorcraft or go home when comes to coils and dizzys
r.barn is offline
post #16 of 21 Old 03-26-2008, 11:10 AM Thread Starter
Erich's Avatar
I am sure I have my old coil still. I will put it back on.
Erich
Erich is offline
post #17 of 21 Old 03-26-2008, 09:11 PM
Pm me if you want some custom length heat resistent wire sleeves. I can make you some
NYstanger is offline
post #18 of 21 Old 03-27-2008, 11:14 AM
Running the same Pre-cut 90* boot Taylor Spirocore wires from like 2000' with a turbo setup and no problems yet...
I should probably replace them though. Going Moroso Ultra 40's next I think.
Troy
79' pace car, blow-threw jytt,stock 302, c4.
10.66 at 126.5
79Sleeper is offline
post #19 of 21 Old 03-27-2008, 03:42 PM Thread Starter
Erich's Avatar
I will try those Morosos too. The Notch is going to be my daily driver soon.
Erich
Erich is offline
post #20 of 21 Old 03-27-2008, 07:29 PM
bfi-93's Avatar
moroso ultra 40's suck my ass. I had a new set turn into junk in 3 months on a N/A car with a 438 in it. These were also only ran at the track with no highway miles on them. Don't wast your $.
bfi-93 is offline
post #21 of 21 Old 03-28-2008, 06:46 AM Thread Starter
Erich's Avatar
So it looks like everybody has trouble with something-so nothings good?
Somehow I doubt that.
79sleeper-if your wires are working well, maybe you should keep them. This is an annoying game to be part of!!
I am wondering if my crimping somehow was affected by heat. The taylors seem like they are good quality. The hardest thing was getting good crimps. If you strip them a little wrong or crimp them not right, the ohm meter will tell you. But this case, it seems that the meter is not telling. The missing is not continuous. But it is there all the same. I'm calling taylor to see what they have to say.
Erich
Erich is offline
