vacume diagram - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 03-20-2008, 03:45 PM Thread Starter
aod1992's Avatar
vacume diagram
Does anyone have some type of vacume diagram of where everything should go. This is for my 92 mustang B&G hotside with mpt70, turbonetics 38mm wg, vortech maxflo bov, and a manuel boost controller. Thanks!
aod1992 is offline
post #2 of 2 Old 03-20-2008, 07:11 PM
xr8240's Avatar
Show us some pics...
As systems vary and we don't want to give you wrong info..
Generally the vac line to wastegate is the bottom one..
A manual controler is placed in this line from turbo ..
OR if you want to be more scientific from boost side to the top of wastegate...
This should be done carefully or on dyno where close attention is on boost, tune...
The bov is vacuum between throttle body and engine so it reads vacuum to activate bov...
xr8240 is offline
