O2 sensor locations? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 03-19-2008, 06:49 PM Thread Starter
vbstng's Avatar
im doing a DIY turbo buil and thinking about the oxygen sensor locations? one is in the downpipe right? where is the othe location? im new to the turbo thing.
vbstng is offline
post #2 of 11 Old 03-19-2008, 07:04 PM
no less then 24 and no more the 32 inches from the outlet of the turbo. to close and to far will screw with the readings.
CollinsAutomotive is offline
post #3 of 11 Old 03-19-2008, 08:37 PM
nice info
Turbomustang
Mesarina is offline
post #4 of 11 Old 03-22-2008, 06:41 PM Thread Starter
vbstng's Avatar
both in the down pipe? my d.p. has only one inlet for the sensor? wheres the other one go?
vbstng is offline
post #5 of 11 Old 03-22-2008, 09:26 PM
If you are getting tuned you can run just one o2. I am using tweecer and have one turned off so I just use the passenger side one.
1994 Turbo GT
mustangless is offline
post #6 of 11 Old 03-22-2008, 09:46 PM Thread Starter
vbstng's Avatar
is it hard to use and understand the Tweecer??
vbstng is offline
post #7 of 11 Old 03-22-2008, 11:58 PM
rob
rob's Avatar
Trader Feedback: (23)
add the second next to the other o2 sensor.
hellion has their o2's in the crossover area without problems.
i don't see air fuel changing when it comes out of the turbine.
rob is offline
post #8 of 11 Old 03-23-2008, 08:46 AM Thread Starter
vbstng's Avatar
where would i get an o2 sensor bung to just add it in my downpipe?
vbstng is offline
post #9 of 11 Old 03-23-2008, 09:04 AM
There is lots of things to learn with it, but there is some help on the eectuning board too.
1994 Turbo GT
post #10 of 11 Old 03-23-2008, 09:27 AM Thread Starter
vbstng's Avatar
yeah i hear that, my downpipe i bought used and the o2 sensor loocation now is 6" from the torbo outlet.. a little close... i was going to close that one and since my downpipe is only 29" long, i was going to put two more bungs 18" and 24" from the tuirbo?
good?
vbstng is offline
post #11 of 11 Old 03-27-2008, 12:18 PM
cesna150's Avatar
Trader Feedback: (29)
i dont run o2's. when car was tuned they were eliminated. no egr either if it matters>
cesna150 is offline
