Vortech S-Trim rebuild instructions inside - Page 4 - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
post #106 of 291 Old 02-15-2007, 05:46 PM
92rohcp's Avatar
Trader Feedback: (52)
I did another inspection of the gears where they mesh together when the noise occurs. This was the spot I suspected may have some scratches or debri causing the nosie. This time I used and 8 power magnifier loop to inspect the teeth nothing at all it looked perfect. I even used a tooth pic and cleaned inside the grooves of the teath. Noise or harness still occurs on that spot.
Now I'm debating weather or not I want to try and run it like this and see how it sounds. Or check the bearings in the gear case and risk destroying another high speed bearing when pressing the impeller off the shaft. I really can't see how the new low speed bearing in the gear case could be causing this noise.
15 GTPP OW 2.9L Whipple
SOLD 92LX Dart 363 KB2.8LC Custom A2A with Stinger PIMP EMS 11.4 ET trap 138 MPH no Dyno time.
"The sound is unnatural and not of this world, like a screeching velociraptor with the flames of hell licking it's ass"
92rohcp is offline
post #107 of 291 Old 02-15-2007, 06:09 PM
avbcon12's Avatar
Trader Feedback: (26)
have you tried to run oil in it to see if it will clear any small sediment out?
adam
90 GT black, V2 SI-Trim, Blow-Thru A/A Intercooler
stage 3 "Y" heads/ Bennett Racing intake, TFS#1, long tubes, 3"Pro-Dumps/H-pipe, TKO500, 3.55's, Home made TA and PHB, cobra brakes, 22 gallon Fuel Safe Cell, PMS tuned etc.. built for twisties
avbcon12 is offline
post #108 of 291 Old 02-15-2007, 08:59 PM
92rohcp's Avatar
Thanks for the idea. No I have not yet run oil in it. I used an asembly lube for bearings on everything. I thought that too, maybe after running it with oil it would clear up.
92rohcp is offline
post #109 of 291 Old 02-16-2007, 09:08 AM
avbcon12's Avatar
well im just thinking that even the smallest piece of anything will cause a rough spot in really tight clearances. who knows, an eyelash could have fallen from your face and lodged itself into the bearing or something... far fetched but you get the idea.
i would plug the drain and fill the case with oil, spin it by hand multiple times back and forth to see if it helps.
adam
avbcon12 is offline
post #110 of 291 Old 02-16-2007, 04:30 PM
92rohcp's Avatar
Yep seems like a good idea. I will fill the case tomorrow and try flushing it out. Funny thing I notice and don't really know how or why this would happen, But if I spin the blower in the other direction the noise is almost non existant.
92rohcp is offline
post #111 of 291 Old 02-16-2007, 04:41 PM
Thanks. That was a great description. On a differnt note, does anyone know the policy here about posting a link to this thread on other boards? My Vortech S/C is in a '94 4.0 Ford Ranger. I happened onto this board and thread via google. This information would be very informative and helpful to others who have a Ford/Vortech combination but not in a Mustang. I would like to post a link to this thread over at rangerpowersports, would this be a problem?
Many thanks once again!
mongoose1 is offline
post #112 of 291 Old 02-16-2007, 05:22 PM
92rohcp's Avatar
I'm glad you understood my explanation. I sometimes take a simple thing and over due it. I don't think posting a link to this thread would be a problem.
92rohcp is offline
post #113 of 291 Old 02-17-2007, 12:58 AM
Has anyone had a compressor seal go out on their Vortech. I have lost around 4psi of boost and changed every gasket and checked every vacum line on my car. Also I have noticed a large increase in the positive crankcase pressure. The only thing that I can think of left would be either the valve seals and the piston rings are bad or that the compressor seal on the supercharger is bad. Is this a possibility or does anyone else have any ideals?
MatthewB is offline
post #114 of 291 Old 02-17-2007, 08:27 AM
92rohcp's Avatar
My compressor seal was leaking oil and that was the reason for my rebuild. I've never heard the seal bleeding boost into the sc case causing back pressure in the engine. Although it sounds possible. But here is the thing how could the compressor seal leak oil into the blower discharge and at the same time bleed boost off into the blower case. Seems to me it would be one or the other.
92rohcp is offline
post #115 of 291 Old 02-19-2007, 12:11 AM
Guys,
I am not sure what bearings this guy is selling but he sells rebuild kits on ebay for $170. It might be worth checking out.
http://cgi.ebay.com/ebaymotors/Vorte...QQcmdZViewItem
Scott Beltz
94GT Vortech YSi, 393, AFR 225 heads, Victor EFI intake, Ford EPEC, PA Supercomp C4.
94 White Cobra, 408 stroker, AFR 205 heads, CamResearch Cam, Tweecer RT, Tremec TKO, Griggs GR40, Koni D/A.
95 Lightning Vortech YS Trim intercooled 393, AFR 185 heads, Tweecer RT.
hollandl is offline
post #116 of 291 Old 02-19-2007, 07:50 PM
92rohcp's Avatar
Originally Posted by hollandl View Post
Guys,
I really doubt that the bearings for the impeller shaft are angular contact bearing.
92rohcp is offline
post #117 of 291 Old 02-20-2007, 10:21 AM
92rohcp's Avatar
I filled the gear case with oil and spun it by hand both ways trying to work anything out of the gears if possible. I noticed again that when turning counter clockwise the rough spot is almost nonexistant, but when turning the normal direction clockwise it still has the roughness at the same spot. It must be the gear timming or something I can't figure out. Well its mounted back on the car and I'm waiting $$$ to buy my new MAF. I'll chime in when I get it running to give an update.
92rohcp is offline
post #118 of 291 Old 02-24-2007, 09:08 PM
92rohcp's Avatar
Guys,
I asked this Ebay seller for the the part numbers for his bearings and if he sells the High speed angular contact thrust bearings. He has not responded to me and that was last week.
Here is a link to another ebay seller who claims to sell the correct angular contact thrust bearing. His price is what I paid for all my parts sourced from different suppliers, looks like a good deal url]http://cgi.ebay.com/ebaymotors/VORTECH-Super-Duty-Rebuild-Kit-V-1-2-5-7-9-etc_W0QQcmdZViewItemQQcategoryZ33741QQihZ016QQitem Z260089158921QQrdZ1[/url]
92rohcp is offline
post #119 of 291 Old 03-24-2007, 05:55 AM
92rohcp's Avatar
After a much needed vacation break to Florida. I'm back and was able to finish and test the blower. I Installed the last part I was waiting for a new PMAS Velocity MAF, "Its Huge", 105mm at the bell opening and 95mm at the narrowest point. Anyway start up was flawless and my newly rebuilt SQ idled perfect. The sound was sweet to my ear, a slight whistle at idle below 900 rpm and at 1200 rpm all but the sound of the engine could be heard.
I will post again in a couple of weeks when the roads are dry. We still have snow in the roads. I'm confident that the rebuild will hold up to all I throw at it.
92rohcp is offline
post #120 of 291 Old 04-07-2007, 10:04 PM
great article guys. i recently sent my t-trim back to vortech for a freshening up (worked great when removed) vortech let me know the whole unit was junk and only thing reusable was the volute. wanted me to give them my old unit and purchase a new one(if old unit was junk why did they want it)so i did purchase a new one just not a vortech.hello novi 2000
gray_cobra is offline
post #121 of 291 Old 04-08-2007, 06:41 AM
92rohcp's Avatar
Oowch....Was there any noise or oil leakage when you sent it to vortech. Did they give anything in trade for the Novi.
By the way I've made a dozen wot passes to 5800 rpm and my rebuild is looking good.
92rohcp is offline
post #122 of 291 Old 04-08-2007, 02:03 PM
t-trim
yes it had become louder-bearings needed changed-but it still worked great. it had no noticable play anywhere. i also had to buy back my own blower for $100(teardown fee). they offered a credit of $400 toward RETAIL of a new head unit which even after said credit was more than superchargers online wanted straight out.hopefully paxton treats its customers better since i switched to a novi 2000.by the way i still have my old t-trim which needs rebuilt and i would like to try it myself but i sold my impellar to a friend who grenaded his. do you know where i might find another?
post #123 of 291 Old 09-20-2007, 08:04 PM
Trader Feedback: (27)
I just found this thread, could anyone tell me where to get both the o-rings for the case in the vortech or at least the part #'s for them?
StangSleeper is offline
post #124 of 291 Old 09-20-2007, 10:47 PM
take a picture of the oring you need. i got my parts locally at a bearing shop.
adam` is offline
post #125 of 291 Old 09-22-2007, 11:22 AM
Trader Feedback: (48)
Don't know whether u know it or not, but Vortech & Paxton R one in the same now & have been for appx 2-3 years...Can't remember the date that they married!!!
midnightrider is offline
post #126 of 291 Old 02-23-2008, 01:01 PM
Back from the dead ...
This is a really old thread! It's amazing how quickly time goes by.
I sold my car about a year ago and have fallen off the map with respect to the mustang community.
I get emails from the internet from time to time asking me about the rebuild, how the car is doing, etc. To help address those questions and to make the rebuild instructions more complete, I've gone through and collected a lot of the information posted by NotoriousNotch, Dedicated5.0, and 92rohcp and updated the write-up. If anyone is interested in the updated instructions or doesn't mind hosting the new file, please shoot me a PM or email me and I will send the new file to you.
The new file is ~1.6MB.
Cam
94 GT
Stang94GT is offline
post #127 of 291 Old 09-03-2008, 06:32 PM
This is a great post!
I'd send it to Vortech, but the blower would be down for more than a week.
It sucks that they're in California and I'm not.
GT RED Wolf is offline
post #128 of 291 Old 09-03-2008, 11:19 PM
DSBLK93GT's Avatar
Trader Feedback: (47)
I would love the file to save in my documents!
2011 GT500
Race Red/white w/SVTPP & Electronics package - ex Ford media/press vehicle
'93 LX
Reef Blue, 5spd, Vortech Si-Trim, 6037s, TFS 1, 1.7 RR's, Cobra intake, 65mm TB, 60lbers, BA2400 maf, 3.73's, & more [email protected] 1.9x 60ft *SOLD*
DSBLK93GT is offline
post #129 of 291 Old 09-04-2008, 02:48 AM
PM me your email address and I'll send it over.
Cam
94 GT
post #130 of 291 Old 09-06-2008, 09:54 PM
StarrMan's Avatar
Here's the updated file in PDF format.
Right click and choose "Save As" to download and save to your pc
Supercharger rebuild instructions 2-22-08.pdf
In Loving Memory, My Son, Anthony Michael Starr 08/14/2007 - 01/21/2008
- 95 GT - Aluminum Heads, Cam, TMoss Cobra intake, S-trim, SCT BA2400, 55's, Longtubes, McLeod bell, TKO-600, 3.55's, etc
- 02 GT (Wife's Toy) - Auto, 4.10's, Lowered, Off Road X, Predator Tuner - [email protected]
StarrMan is offline
post #131 of 291 Old 09-06-2008, 10:57 PM
Thanks for hosting!
Cam
94 GT
post #132 of 291 Old 09-07-2008, 08:47 PM
Yes, thanks for hosting it.
area51 is offline
post #133 of 291 Old 09-10-2008, 04:11 AM
AutoStang's Avatar
when i pulled my input shaft out the bearing stayed in the case
how are guys getting these out if the bearing stays stuck in the case.
i've tried alot of things with no luck
is there a tool to use?
thanks
AutoStang is offline
post #134 of 291 Old 09-10-2008, 04:22 PM
AutoStang's Avatar
nothing?
/cry
tried a slide hammer with the 2 fingers that fit under the bearing
not budging
can i heat the case up?
thanks
post #135 of 291 Old 09-10-2008, 04:25 PM
Originally Posted by AutoStang View Post
nothing?
/cry
not budging
thanks
You might have to apply some heat to the case. I wouldn't heat the case up to much though as it is still cast aluminum. If I remember right when mine was rebuilt we had to do the same thing to get the bearing out...
'91 GT: SOLD
'04 GT: Forged bottom end, MHS Stg 3 PI heads, Hi-Tech Custom Cams, MHS Vic Jr + elbow, custom turbo kit, Precision 7175, T-56 & 3.27's. 785rwhp/725rwtq @ 20 psi.
Macs Stang is offline
post #136 of 291 Old 10-09-2008, 03:37 PM
Just out of curiousty, how long did your SC hold up after using the attached rebuild instructions?
silvergoat69 is offline
post #137 of 291 Old 10-09-2008, 11:21 PM
AutoStang's Avatar
about 50miles
lol
imo you should use the high speed seal that vortech uses
anyone know where i can get one of those seals
post #138 of 291 Old 10-16-2008, 06:59 PM
After looking at my post I did mine almost exactly 2 years ago and it is still going fine. I haven't put a ton of miles on mine but it has definitely been beaten to death since the rebuild.
Silver86 is offline
post #139 of 291 Old 12-03-2008, 01:18 PM
the_bock's Avatar
site was purchased ?
Not working...
93 black coupe : DEAD Dart 364, TW, TFS-r intake, 60 lbs inj, DBX 97mm, 75mm tb, V2 Si, PMS,, 31 spline.
[email protected], 1.43 60 feet with A5.
[email protected] 137mph 1.45 60 feet with built aod.
the_bock is offline
post #140 of 291 Old 12-03-2008, 03:46 PM
StarrMan's Avatar
which site is that?
scroll up to post #130 and I have a link to the pdf file
StarrMan is offline
