what is the smallest 8 rib pulley you have used without slipping? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 29 Old 11-27-2012, 04:35 PM Thread Starter
what is the smallest 8 rib pulley you have used without slipping? what tricks did you use t o help?
Silver LX is offline
post #2 of 29 Old 11-27-2012, 06:29 PM
v8powerv8jim's Avatar
I will be using a 2.75" 8 rib soon,going to get it coated in a carbinite type textured coating to help eliminate slip.
Would have preferred an 8" crank pulley tbh,but difficult/costly for a 94-95.
94 gt 342 Forged Stroker B50 block,faceplated TKO & Lakewood,Spec 3 clutch,HP 76mm Turbo,Victor JR heads,1.6 RR,B41 Cam,TFS Box R intake,90mm TB,Vortech Maxflo fuel kit/rails,60lb inj,MSD Blaster,Pro Billet & 6AL
v8powerv8jim is offline
post #3 of 29 Old 11-27-2012, 06:30 PM
MARK 302's Avatar
On a s-trim a 2.95 , on a t-trim a 3.12. That was the smallest I have tried on either.
92' lx hatchback.
NEW BEST/NOVI 1500 Dart 347 [email protected] [email protected] TKO600
2010 GT500 517rwhp [email protected] on stock tires.
1992 LX 5.0 GT40P setup.
MARK 302 is offline
post #4 of 29 Old 11-27-2012, 11:13 PM Thread Starter
anybody go under 2.80 with success?
post #5 of 29 Old 11-28-2012, 12:12 AM
S-Trimmed302's Avatar
Trader Feedback: (124)
anything under a 2.95 and an 8 rib is gonna slip no way around it.If at all possible its
best to go with a larger crank pulley and stay with a larger blower pulley.
My 92 Coupe- Under construction - Dart 347, TFS 205 11R heads,Custom Cam by Brian Friedentag "freezy74",TFS Box R Intake, 75mm Accufab TB, Hooker Supercomp 1 3/4" Full Lengths,Vortech Pass side YSI,8" Crank,2.85 blower pulley,Treadstone 1245-28 Intercooler,Snow Stage 2 Meth kit
S-Trimmed302 is offline
post #6 of 29 Old 11-28-2012, 09:25 AM
10sec5oh's Avatar
Trader Feedback: (71)
I've used a 2.75 with an 8" lower on my YSI. Get a Kurgan brace if you're going to try it, belt needs to be beyond tight!
89 LX S-trim and GT40's
10sec5oh is offline
post #7 of 29 Old 11-28-2012, 01:07 PM
Trader Feedback: (48)
ALL serpentine belts have some slip. Obviously the larger the crank pulley(8") & the greater amount of ribs(10)the less slip U have. I've ran 2.50 SC pulley, 8" crank w/10 ribs and had good success!! Doesn't get ANY better than that IMHO, unless Cogs..
midnightrider is offline
post #8 of 29 Old 11-28-2012, 03:54 PM Thread Starter
what does the kurgan brace do exactly? does it help keep the belt super tight? it looks like it really hard to adjust as it is squeezed in there? how do you adjust it?
post #9 of 29 Old 11-28-2012, 03:55 PM Thread Starter
i laso heard that 10 rib belts are harder to find than 8 rib and that the options are not as good- is this true?
post #10 of 29 Old 11-28-2012, 06:19 PM
MARK 302's Avatar
Kurgans brace lets you get the belt as tight as you want without flewing the blower. Itr probibly takes some pressure off of the crank also. It connects the upper pulley to the lower pulley with a bar basically.
92' lx hatchback.
MARK 302 is offline
post #11 of 29 Old 11-29-2012, 07:07 AM
this is an open ended question... the reason is the bigger blowers, like the ysi etc, require more HP to turn at higher RPM... that being said, more tension or a larger pulley is required... also, it depends on your tensioning system! You can get away with a much smaller pulley on a foxbody then a mod motor because the mod motor uses the factory tensioner with a spring... if you give more details, i can give you my experience..
PLEASE EMAIL --->
<--- DO NOT PM for prices or tuning!
815-669-RACE (7223) <--- Sales
Please visit our e-store --->
Chicagolands largest Vortech dealer since 2006!
We stock many parts! If you dont see it, just ask!
Before you buy ANY mustang part, give us a chance. We accept mastercard and visa.
Authorized SCT, AEM, Diablosport, Vortech, Paxton, BS3, FAST, UPR, PA Racing, Harland Sharp, Team Z, GMS, Trickflow, Kooks, and MANY MORE!
flyin_hawaiin is offline
post #12 of 29 Old 11-29-2012, 09:02 AM
scott88's Avatar
Trader Feedback: (21)
Any link to see/purchase this brace? I tried to find it on the Kurgan site but could not.
Scott
88 Supercharged LX Coupe
2004 Suburban LT
scott88 is offline
post #13 of 29 Old 11-29-2012, 09:47 AM
10sec5oh's Avatar
Scott
https://forums.corral.net/forums/supe...wer-brace.html
10sec5oh is offline
post #14 of 29 Old 11-29-2012, 10:56 AM
8/2.75 seeing 20+ psi with a ysi KMS tuned.......seems to hold pretty steady with what i can see but like others have said, tighten the snot out of it.
1993 GT
newpony is offline
post #15 of 29 Old 11-29-2012, 01:33 PM Thread Starter
Bob- set up is a 89 lx with a si trim. 8 inch lower presently.
post #16 of 29 Old 11-29-2012, 03:24 PM
Trader Feedback: (38)
not to hijack but i was planning on running the stock 6.75 crank pulley with a 2.75 blower pulley on my s-trim-is it going to slip bad?
Marty White is offline
post #17 of 29 Old 11-29-2012, 04:13 PM Thread Starter
i would go to 8 inch crank to start
post #18 of 29 Old 12-03-2012, 12:42 AM
swinerton's Avatar
Trader Feedback: (15)
2.85" Traction improved pulley, and the largest crank damper you can fit. 7.50" (15% OD). You can fit this fairly easy with minimal grinding of the crank trigger boss. You can also still use your regular water pump pullley.
7.75" (18% OD) will require an electric water pump, and serious modification to the timing cover.
Cory Swinerton
2013 Boss 302 #540 712rwhp/592rwtq (SOLD)
1999 GT 2V 775rwhp Ysi, Boss 304". (SOLD)
Originally Posted by WhiteLX408 View Post
Running street tires at the track is like wiping your ass with a turd.
swinerton is offline
post #19 of 29 Old 12-10-2012, 12:45 PM
tubbedstangeater's Avatar
Ran all the way down to a 2.5 pulley. Ran the gatorback 8 rib on all. Below 2.75 will slip. 2.95 pulley had same boost as 2.5 and 2.75 pulley I assume it just slips. Had plenty of belt wrap and cranked extremely tight.
336ci, twin 66 turbo, diamond 9.5cr pistons, boss block, eagle forged crank ,80mm accufab,bullet cam, Msd 6al, Holley Hp wideband system, trick flow box r intake, front mount, 3400lbs, 3200 stall, c4 transmission, 06gt, best 1/4 9.876 135.75 1.41 60ft , A1000 pump,80lb injector
tubbedstangeater is offline
post #20 of 29 Old 12-25-2013, 05:16 PM
Trader Feedback: (46)
I have done 2.80" and 7.00" with a S-trim with no problems but that was a 10 rib setup and no brace on a Foxbody, now I have a 95 with a 8 rib 6.87" crank pulley, I know a 2.95" blower pulley will work without slipping but could I use a 2.80" or 2.85" without a brace and no slipping?
88 GT 331 NOVI 2000
88 Coupe 306 70mm TURBO 9.75 @ 142 MPH
95 Cobra R #75-SOLD 06 F250 XLT Sport
17 GT350 GOD'S NOT DEAD
racsirx is offline
post #21 of 29 Old 12-28-2013, 08:43 PM
Anybody?
88 GT 331 NOVI 2000
racsirx is offline
post #22 of 29 Old 12-28-2013, 09:53 PM
Anybody?
you're always gonna get some slip. No reason not to try it. Read my earlier post.
post #23 of 29 Old 12-28-2013, 11:10 PM
RBELL's Avatar
The first Vortech supercharged car/ first supercharged car I ever worked on or tuned, had a pulley that I measured at 2.48". It would shred belts, a belt would only last about three passes, before it broke. After two passes you could see daylight through the belt. After a lot of experimenting, making a blower brace, then finally adding a idler pulley. The idler pulley fixed the problem, no more belt slippage. The car was pretty wicked once the belt problem was fixed.
If I buy a part or parts from you do not send me those parts through USPS, I would actualy like to get the parts I purchase.
RBELL is offline
post #24 of 29 Old 05-26-2019, 11:18 AM
I'd like to revive this thread lol I wonder if there has been any new ideas and experiences ?
I am just moving from my T Trim to a YSI hoping for 750whp on E85 , E98 barrel fuel backed off so it's super clear and clean
I have a 10% overdrive Crank an underdrive Alternator and underdrive water pump pulley. I ran a 2.95 on my T Trim with honestly no belt slip. Some say the YSi need more energy /torque to spin the unit ? Any more feed back or results running a 2.75 or 2.8 blower pulley with a 10% crank with their ysi ?
Belt sizes ? And brand ....
Thanks in advance
Billy Martin is offline
post #25 of 29 Old 05-26-2019, 02:07 PM
AlexLTDLX's Avatar
Not a ysi, but I run a 2.75 on my whipple - it's got heavy rotors. In my experience, the tensioner is more important for dealing with belt slip than the pulley. With a manual tensioner, I had to run more than twice as much belt tension as I do with my custom-built spring loaded tensioner. Two other things: the fleetrunner (green) and newer blue blower belts are the only way to go (forget gatorback - they're like rubber bands; and much less robust), and most pulley treatments (cross grooves are what I've tried) don't do much for slippage and just wear belts out faster.
It's all in the tensioner.
AlexLTDLX
AlexLTDLX is online now
post #26 of 29 Old 05-26-2019, 02:21 PM
AtomicCoupe's Avatar
Dude, I love the stuff you come up with. Seriously, anything you post, I’m reading. Just had to say...
Stock block 306, V1 T-trim, AFM B-451 cam, TFS Twisted Wedge, Holley Systemax, A1000, Snow Meth, TKO 600, Team Z, Strange, MM, Lakewood and Moser helps me go forward fast.
AtomicCoupe is online now
post #27 of 29 Old 05-26-2019, 02:46 PM
AlexLTDLX's Avatar
Wow, thanks. I'm honored. But I do make TERRIBLE life choices. Car stuff, not so much...
BTW, I'm not really going nuts posting stuff on the Corral (or any forum for that matter) any more. The Corral and Yellowbullet both hosed my threads with pictures - they no longer "trust" outside FTP servers for hosting images. I'm putting stuff up on my youtube channel instead. In fact, I'm making a new video today.
AlexLTDLX
post #28 of 29 Old 05-26-2019, 02:55 PM
Thanks for the advice on belts and the tensioner. I swapped my timing cover and vortech mounting bracket out to accept the 3 bolt THUMP RRR Tensioner when I did my 8 rib upgrade. and that did away with slippage I had years ago with the 2.95 6 ribbed . Dyno visits are costly from where I live as are belts and pullies shipped to Canada, so I am just trying to make some decisions before I hit the rollers. Thanks guys
post #29 of 29 Old 06-14-2019, 09:12 AM
Alright corral forum friends. I have the Ysi bolted up on my 99 timing cover with the Thump RRR Racing tensioner. Man that tensioner is stiff &#x1f609; I ditched the 2.95 8 rib for.a 2.7. I installed the Metco Overdrive alternator pulley (really large) and with the 10% Innovators west crank pulley I was able to walk the KO81145 belt on that I was using with factory alternator pulley and the 2.95. But now the belt is just a bit tighter &#x1f642; but the tensioner still looks in good range gear for added tension on the belt. I am due to hit the rollers a week from today and I will keep you all posted with updates .
For Sale Complete 8 rib setup for 96-98 cobra with vortech pulley mstngcobra Modular Engine Parts 4 11-14-2012 06:47 PM
For Sale BGG Performance 8 RIB Pulley Kit PEDD92LX Modular Engine Parts 5 04-30-2012 08:47 PM
For Sale F1A Procharger, 8 Rib setup, IW Crank pulley fastmach01 Power Adders 3 02-19-2012 07:18 PM
Question about 8 rib 5.4 crank pulley vs 4.6 6 rib justinschmidt1 SVT & DOHC 0 10-05-2011 07:34 PM
Want To Trade 3.4" 8 rib pulley for 4" 8 rib procharger pulley encasedmetal Power Adders 5 06-02-2011 04:49 PM
