3.8 fot on a 5.0 K member? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 02-26-2008, 02:44 AM Thread Starter
kd7cwg's Avatar
3.8 fit on a 5.0 K member?
I picked up a 3.8 engine/transmission out of a 2000 stang, and plan on tossing in my 83, And need to know if I need the k member from the doner car?
Thanks!
Dan
2001 POS Focus
2002 Crown Vic LX Sport
1997 Suburban K2500
1988 Blue Bird All American
kd7cwg is offline
post #2 of 4 Old 02-26-2008, 09:07 AM
An82Mustang's Avatar
Yes....
88 Sonic blue coupe...-
RIP
89 GT Convertible - Sold it!
2000 Kona Blue GT Convertible 4V
2005 Sonic Blue GT
An82Mustang is offline
post #3 of 4 Old 02-26-2008, 08:59 PM
In theory it should. I know the 87-93 5.0s and 2.3s used the same cradle as the 94-95s. However, in 96 the cradle was redesigned for the 4.6, and adaptor plates/mounts were necessary for the 3.8L to bolt in properly.
So, assuming they didn't change anything in 86 (seeings as how it was the first year for the FI 302) the 3.8 should bolt in. Knowing this, you could reference the motor mount numbers from 86-93 (and possibly 94-95) for the 5.0. If the numbers match the same for your 83, then sure as #### it should fit right down in there.
Cox Abele is offline
post #4 of 4 Old 02-26-2008, 10:54 PM Thread Starter
kd7cwg's Avatar
Thanks for the info!
i looked it up, and the motor mounts have a complete ifferent design, than the 94 3.8 (Have a 94 k member, because no one makes motor mounts to fit the 83 k.)
Looks like I will have to pull the k member off the doner car also!
I suppose I could use the 94 K, but I'd have to buy 3.8 motor mounts for a 94 v6.
2001 POS Focus
1997 Suburban K2500
kd7cwg is offline
