3.8 vs. 5.0 h-pipe differences? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 01-11-2008, 08:19 PM Thread Starter
Scout's Avatar
Exclamation 3.8 vs. 5.0 h-pipe differences?
Are there any? If so what? Anybody
Scout is offline
post #2 of 7 Old 01-17-2008, 08:52 AM Thread Starter
Scout's Avatar
Just in case anyone wondered, there is no difference on a stock 3.8 h-pipe from a 5.0 version.
Scout is offline
post #3 of 7 Old 01-18-2008, 08:00 PM
Noslo5.0's Avatar
Whatcha mean man? The intermediate pipe off my son's 3.8 isn't anything like the one off a 5.0.
Do you just mean that the header locations are close enough that you could replace a 3.8 Y-pipe with an H or X pipe designed for a 5.0 and go true dual exhaust? Based on the fact that the blocks seem so similar in dimension (where it matters, anyway), this doesn't sound like much of a stretch.
'00 V6 conversion - Dart SHP 363, RPM XTs, RPM 2, 1-3/4 LTs, TFS 2 cam, 87mm Pro-M, Fox 80mm TB.
'10 Taurus SHO - defies physics routinely
Noslo5.0 is offline
post #4 of 7 Old 01-20-2008, 10:48 AM
An82Mustang's Avatar
the off road h on the 5.0 car is slightly wider at the collector and is a lot larger in diameter... if you use a set of shorty headers for the v6 and the 5.0 h it should work...
88 Sonic blue coupe...-
RIP
89 GT Convertible - Sold it!
2000 Kona Blue GT Convertible 4V
2005 Sonic Blue GT
An82Mustang is offline
post #5 of 7 Old 01-21-2008, 12:29 AM
What H-pipe? The 3.8 stock has a single exhaust system/y-pipe
Cougarstang is offline
post #6 of 7 Old 01-21-2008, 06:38 PM
Noslo5.0's Avatar
I believe the point of the thread is that you can replace the stock "y" pipe with an "h" or "x" pipe designed for a 5.0.
The 5.0 being only slightly wider at the collectors implies that a little bit of bending is all that would be required to do the swap successfully. I'll give it a try on my boy's six in the near future.
Noslo5.0 is offline
post #7 of 7 Old 02-18-2008, 04:04 PM
IDK but I have long tubes (mac for the v6) and had to have the mac h then bolted onto a 5.0 set of bassani true duals. One thing to think about is where the port thing for the sensors are.
tealpony is offline
