Bad Clutch? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 01-01-2008, 04:33 PM Thread Starter
Bad Clutch?
Lately, I've noticed weird noises coming out of the front of the car when it's in neutral but go away when I press on the clutch pedal. In addition, the clutch pedal has begun to squeak horribly when it's pressed. Is the clutch going bad? I have 94k miles and it's never been replaces or even looked at by a shop.
On the other hand, the car still seems to stay in gear and shift without any trouble.
thx
MustangLou is offline
post #2 of 4 Old 01-01-2008, 05:16 PM
Bad Clutch?
MustangLou: "I've noticed weird noises coming out of the front of the car when it's in neutral, but go away when I press on the clutch pedal. In addition, the clutch pedal has begun to squeak horribly when it's pressed. Is the clutch going bad? I have 94k miles & it's never been replaced or even looked at by a shop. On the other hand, the car still seems to stay in gear & shift w/out any trouble."
The noise you hear is probably the T/O brng. Clutches normally don't make a noise ... they just start slipping until it goes away & the car can no longer move forward. Whether or not your car stays in gear is strictly a transmission function & nothing to do w/the clutch. Shifting can be either a clutch or a transmission problem (bad synchros). Plan on replacing the pressure plate, clutch disc & T/O brng.
'98 GT equipped w/Koni, Eibach, Cobra R rims w/Yokohama tires, Cobra brakes all around & 3.73 gears. Also a Boss330 4.6 Cobra block w/PI heads & stuff from Accufab, ARP, Centerforce, Comp Cams, Fidanza, K&N, Mahle, Manley & Borla exhaust w/Mac Pro Chamber thrown in for grins & giggles.
Geezer is offline
post #3 of 4 Old 01-01-2008, 05:37 PM Thread Starter
Thanks for the info. What does T/O stand for? About how much might a shop charge to swap the pressure plate, clutch, and T/O bearing?
post #4 of 4 Old 01-02-2008, 05:41 PM
T.O. = Throwout (or Terrell Owens )
Cougarstang is offline
