S/C Thunderbird 8.8 Rear end into a 2003 Mustang V6 ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 19 Old 12-03-2007, 10:32 AM Thread Starter
ive got some rear end issues and ive got a buddy with a 8.8 rear end from a thunderbird s/c car and i was wondering if i could use that rear end ? .. and what mods i would need to get it to work right
Thanks, Matt
xXcoolrollinXx is offline
post #2 of 19 Old 12-03-2007, 11:06 AM
FineLineMtrSprts's Avatar
Thunderbird SC..ie Super Coupes have IRS..not solid axle..and it is NOT a bolt in deal into a mustang...totally different chassis. If you want IRS you have to get it out of a 03/04 cobra..and yes it is basically bolt in. If you are just trying to get an 8.8 solid rear you want one of of a TURBO COUPE thunderbird..not a SC.
2003 Tahoe modded..louder..lower
2012 Toyota 4Runner Trail Edition lifted and louder
FineLineMtrSprts is offline
post #3 of 19 Old 12-03-2007, 11:43 AM
Like said before the Supercoupe has a IRS setup. The T-Bird SC is on a MN-12 chassis which is different than you mustang and will not bolt in.
Contact Us:
High volume STOCKING dealer for:
Roush Performance, Ford Racing Parts, Steeda, Maximum Motorsports, Canton, Dart(Blocks & Heads), SCAT, World Products, Edelbrock, Comp Cams, Crane, ARP, Manley, Moroso, Fel-Pro Gaskets, Clevite Bearings, Diamond Pistons, Superchips, Spec Clutch, Ram Clutch and more!!!
Northcoast Perf is offline
post #4 of 19 Old 12-04-2007, 08:54 AM Thread Starter
well i was told that a locker would fix my problem with my 7.5 rear end ... i ordered a Powertrax Locker .. but im not sure if that was a good idea ?
post #5 of 19 Old 12-04-2007, 10:00 AM
The problem with the 7.5 rear is that....well its a 7.5in rear end..just not very strong. How much power are you going to be putting to it?
post #6 of 19 Old 02-09-2008, 09:16 PM
If you paid more than $200 for that Powertrax you could have spent that much on an 8.8 that would have had a Traction Lock and added strength of larger ring and pinion as well as larger differential internals.
Modifying a 7.5 is like polishing a turd.
gnvair is offline
post #7 of 19 Old 02-12-2008, 12:00 AM
I had a 1999 V6 with an 8.8" that Ford bought and installed for me under a service bulletin. There was nothing unsafe about the 7.5, just had a gear whine. I think I was 1 of 180 cars to get the 8.8". My car was also in the factory in Feb 99 when it exploded and shut the line down for a day or so. I found stray parts in the car from where the workers left off what they were doing.
Conversely, never had a failure of anything on that car. Not even the battery. Same battery for 8 years and 127K miles. I had to scrap the car when the #3 cylinder rings went bad and burned 1 quart in 100 miles.
I heard about it a few weeks ago, its now driven by some mexican. The car like all of ours, are unmistakeable on the road.
Ok, no more lame story-- go get yourself a used 99-04 GT 8.8" and it bolts right in, even the quad shoks if you want them, I never used quad's on the 99.
Factory price in 99 for a new 8.8 was $1200.
You forgot about the ramdom gun fire in the streets, RPG's, and the cackle of Klashnikovs on all the major holidays.
LA rules! I love this place.
35thPONY is offline
post #8 of 19 Old 02-13-2008, 01:58 PM
built 7.5 > stock 8.8
8.8s arent even that strong i have blown them up on stock mach 1 power
09 f-350 lariat CCSB 5.4 - DD
04 f-350 RCLB 6.0 - sold
mustangman022232 is offline
post #9 of 19 Old 02-13-2008, 06:52 PM
7.5's usually break teeth of the ring and pinion sets or they grenade the carriers. Never seen an 8.8 break a ring and pinion set (that was set up correctly) and they hardly ever break the carrier. Most 8.8 failures in a Mustang are as a result of a broken axle.
I dont doubt your Mach 1 breaking as I have probably built atleast a half dozen 99-04 8.8's on GT's and Mach 1. All have broken the left side axle. All were basically stock cars being launched on sticky tires.
Axle shafts are the same between the V6 7.5 and the V8 8.8. But you will probably never see a 7.5 break and axle because the carrier or the ring and pinion fail before the axle since those items are the weak spots.
But seriously the reason why I stated 7.5's are junk are because with the small ring gear comes a smaller carrier and smaller spider gears and side gears. Ask any one that owned and raced an 82-85 GT (which came stock with 7.5's. Usually the spider or side gears failed.
I had one friend with an 84 GT who's 7.5 blew up driving over a bump. Driveline basics apply: a larger ring and pinion is able to handle more torque. If this wasnt the case, Ford would still be using the 8.8 behind all the V8 Mustang power plants. They stopped using the 7.5's because of all the warranty claims from blown up 7.5's. Heck, even the V6 Rangers and all of the Explorers came with an 8.8 because the 7.5 was deemed too fragile.
gnvair is offline
post #10 of 19 Old 02-14-2008, 01:16 PM
Of course building a 7.5 is useless since a 8.8 with the same money thrown at it would still be stronger. WAY STRONGER
post #11 of 19 Old 02-15-2008, 10:24 PM
<---- goes to drink punch in the corner and watch silently as the only one in the room who had a 99-04 V6 with an 8.8" with 100,000+ miles on that combo.
35thPONY is offline
post #12 of 19 Old 02-16-2008, 01:47 PM
Not uncommon to see a 8.8 with over 100k miles
post #13 of 19 Old 02-18-2008, 02:19 PM
i have never seen a R&P blow out of a 7.5, 99.9% of the time its the spider gears that blow out on them (hell my stock open blew up on a stock car), and like i said i blew the spiders out of my buddies mach with sticky tires on it as well and a hard clutch drop
there are several 6ers running a 7.5 with either an eaton or detroit true trac LSD in it that are having no problems with 400+ HP, its the ford parts that blow up
post #14 of 19 Old 02-18-2008, 03:58 PM
Where? Junkyard? I'd like to find one but not something I don't know where it's been.
I have a stock 7.5" with 3:73s and am putting down a little over 400rwhp. I recently heard that the supercoupes came with a 8.8" with 3:73s from the factory. A guy on our forum says he got one for $200 and installed himself. For $200 and the gearing I want, that might be worth taking the chance. I just have to make sure I'm looking for the right thing.
tealpony is offline
post #15 of 19 Old 02-18-2008, 04:20 PM
You cant polish a turd dude. Compare the spiders and side gears in ANY 7.5 to even a stock 8.8. They are a lot smaller. Get real and get an 8.8. Putting any money into a 7.5 is like throwing it out the window. No matter what you do to it, it will still be a 7.5.
Adding a detroit or an Eaton to a 7.5 is like putting new wipers on a broken windshield.
gnvair is offline
post #16 of 19 Old 02-18-2008, 04:30 PM
You can use any 86-98 8.8 by swapping your axles and brakes on to it.
I have done this swap into several SN95 cars and you need to drill 2 holes in the lower control arm brackets to screw the brake lines on IF you use an 86-93 rear). 94-98 8.8's will already have those holes.
You can also use an 87-88 TBird Turbo Coupe housing by doing the same. The auto turbo coupes had 3.73's and the 5 speeds had 3.55's.
TBird Super coupes are independent like the 99-04 Cobras.
The guy on the forum probably used a Turbo Coupe rear.
gnvair is offline
post #17 of 19 Old 02-20-2008, 06:18 PM
so why even bother with an 8.8 and why not just go 9"?
post #18 of 19 Old 02-20-2008, 08:02 PM
Because the 8.8 is a more efficient rear powerwise and significantly lighter.
A 9" with its straddlemounted pinion tends to suck up 2-3% more power than a comparable over hung style pinion used in most integral style rears.
Dimensionally, the Ford 8.8 is almost identical to the 65-72 Chevrolet passenger car 12 bolt (ring & pinion sizing, bearing sizing, pinion stem diameter, etc). The down side was that Ford equipt most passenger car 8.8 rears with the same 28 spline axle shafts that were used in the 7.5 where as the Chevrolet 12 bolts came standard with 30 spline shafts. Ford most likely did this as a cost savings since the first 8.8's were used on the fullsize cars (Crown Vics, Town Cars, Grand Marquis) which came with 7.5's from 79 until the 8.8 was introduced. Ford basically kept everything the same from the axle tubes outwards. They did the same thing in 1986 with the 5.0 Mustangs.
I know you had mentioned breaking carriers, but if you have never compared a 28 spline 8.8 carrier to a 31 spline carrier, you will see a significant difference in the size on the 31 spline units. The cross shaft and gears are physically bigger. Thats not to say a 31 spline wont break, but then again, you can break ANY carrier with enough torque and shock. I know plenty of people (including myself) who have blown up Auburn Pro's and Eaton's.
I know quite a few guys who have been in the 8's with 8.8's and if you talk to many guys on here and at the track you will find the samething.
gnvair is offline
post #19 of 19 Old 02-21-2008, 04:26 PM
9in is also more expensive..thats one reason a lot of guys stick with the 8.8. Also you can mod a 8.8 to be pretty much just as strong as a 9in,using 9in axle tubes and 33spline axles. Of course guys running those are making serious POWER.
