Idle Hanging @ 2000 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 11-20-2007, 11:16 PM Thread Starter
OldFourEyes's Avatar
Idle Hanging @ 2000
I got a buddy with a 94 3.8 Mustang (Auto trans.) and his idle's hanging up at 2k, doesn't matter if it's cold or hot. Put it in gear and it jolts the car and hangs at 1k while in gear.
I'm just curious if this is a normal issue, if it's an easy fix, and if the 3.8 is like the 5.0 at all in the matter of Idle control and such.
He had a diagnostics run on it at auto zone and they told him his o2's are dead, and that his Cam Sensor may have gone bad. Now, these don't sound like idle altering issues to me; but I've no experience with 3.8's. Any advice is greatly appreciated.
'89 5.0 LX
Stock Shortblock, Stock 40p's w/ TFS Springs, TFS 1 cam, CSU Blow-Thru, t70, AOD, OE Suspension components
Best to date: 1.50 60ft [email protected]
OldFourEyes is offline
post #2 of 4 Old 11-24-2007, 01:36 PM
Might be the IAC or the TPS
Cougarstang is offline
post #3 of 4 Old 12-21-2007, 04:45 PM
MYLITTLEHO's Avatar
try the TPS sensor.. Mine idle was hanging high and it was a bad TPS sensor.
Best E.T to date 14.02 @ 98.7
MYLITTLEHO is offline
post #4 of 4 Old 01-01-2008, 04:25 PM
Ditto the bad tps sensor.
MustangLou is offline
