Cold Air Idle Screw Up? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 11-07-2007, 08:47 AM Thread Starter
jonb347's Avatar
Trader Feedback: (57)
i put a cold air intake on my 2000 3.8l and now it idles high for a second, then drops to normal. also, when you push the clutch in it stays at high idle instead of dropping for a few seconds. i put on a new iac valve and it still does it. i unplugged it and it runs fine, so its something to do with the iac but a new one didnt fix it. any help would be good.
1993 DOHC Project "Jessica" 2007 Shelby GT500
1968 351w Coupe "Athalia" 1969 Fastback 408w
2013 Focus "STacy"
jonb347 is offline
post #2 of 5 Old 11-30-2007, 07:56 AM Thread Starter
jonb347's Avatar
2013 Focus "STacy"
jonb347 is offline
post #3 of 5 Old 11-30-2007, 05:05 PM
Any chance you forgot to plug one of the holes in the intake? I had to when I installed it on my old 2001 3.8. Having that exposed might screw with the idle
Cougarstang is offline
post #4 of 5 Old 12-02-2007, 12:25 AM
tx_zstang's Avatar
Depending on the CAI, you'll need to tune the car to recognize the difference in air intake flow.
2005 Forged/stroked/cammed 5.0L -- twin turbos --
previously, KB 2.6L stage2 @18 psi; 10.74 @128
2006 4.0 V6 with Powerhouse turbo and TR6060
tx_zstang is offline
post #5 of 5 Old 12-02-2007, 12:41 PM Thread Starter
jonb347's Avatar
ya i unplugged the battery and when i did it and i though it was supposed to recognize the new parts and tune according to it? or do you mean manually? i messed with the idle a bit but it didnt solve my problem.
2013 Focus "STacy"
jonb347 is offline
