rear defroster not working? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 10-13-2007, 10:28 PM Thread Starter
the light on the switch comes on but nothing happens in the back window.....it satrting to get cold and i cant see out the freakin windows in the morning.......does anyone know which fuse or anything else to check? I lost my user manual....
thanks
1994 Cobra,stock motor,Tremec 3550,McLoed dual disc clutch,Billet steel flywheel,SFI bellhousing. Fox length Aluminum driveshaft with 5/8" spacer,Lowering springs,adjustable upper control arms,non adjustable lowers,FRPP Diff,31 spline Strange axles.17X9 10th anniversary wheels, 245/45/17,275/40.
bdhollie is offline
post #2 of 5 Old 10-14-2007, 05:42 AM
homank76's Avatar
Make sure that the electrical connections are still plugged in at the window.
If the light comes on, its not a fuse.
Typical 97 vert with 8-point roll bar.
homank76 is offline
post #3 of 5 Old 10-14-2007, 10:21 PM
svpstang's Avatar
I have a 95 as well & the Solder broke on my connector that right on the glass. To see if this is the problem, try "Bridging" the connection with some needlenose pliers, hold one to the metal part of the connector & one to the metal filament on the glass. You'll need to see a glass shop to repair the connection.
svpstang is offline
post #4 of 5 Old 10-17-2007, 07:13 PM
j87gtmd's Avatar
Trader Feedback: (35)
You can also use a test light...even right on the grid for the defr.
mine got messed up when the glass guy was putting in the new window after paint job.
I used solder to fix it.
87 GT
j87gtmd is offline
post #5 of 5 Old 10-28-2007, 08:20 PM
svpstang's Avatar
Mine actually still dosen't work, I tried to solder myself & couldn't get it to hold on (since I was actually working upside down.) How'd you do it??
svpstang is offline
