strange heater problem...... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 10-12-2007, 09:23 AM Thread Starter
when i start the car to get it warmed up and turn the heater on it gets really hot(almost to the notch past the "L" on the normal gauge...... and the heater blows cold..... once i start driving it cools back down and then starts blowing hot like its supposed to......
any ideas why this is happening? its annoying becuase id liek thecar to be warm for my son before i put him in there....
thanks!!!
1994 Cobra,stock motor,Tremec 3550,McLoed dual disc clutch,Billet steel flywheel,SFI bellhousing. Fox length Aluminum driveshaft with 5/8" spacer,Lowering springs,adjustable upper control arms,non adjustable lowers,FRPP Diff,31 spline Strange axles.17X9 10th anniversary wheels, 245/45/17,275/40.
bdhollie is offline
post #2 of 6 Old 10-18-2007, 09:28 PM
Might be a bad heater core. Not a fun job if it is.
Since the temp gauge is fluctuating, that tells me that coolant isn't flowing correctly somewhere
Cougarstang is offline
post #3 of 6 Old 10-19-2007, 11:28 AM Thread Starter
I tried a new thermostat and it seems better.......hard to tell now that its cooling off.....
bdhollie is offline
post #4 of 6 Old 10-22-2007, 07:50 PM
It's could very well be a blown head gasket.
05 Mustang GT mods: tri-ax shifter, SCT tune, JBA long tubes
96 mustang 4.2L procharged v6 mile time [email protected]
38stang is offline
post #5 of 6 Old 10-23-2007, 01:07 PM Thread Starter
i didnt see any coolant in the oil so i dont think its that... it seems to be running fine for now since its colder....
bdhollie is offline
post #6 of 6 Old 11-03-2007, 10:00 AM
svpstang's Avatar
My Guess is the thermostat, or a Bad Rad. If you don't smell coolant (Sweet Smell), then it could be much worse like the head gasket.
svpstang is offline
